Sean
Posted: Thu Sep 08, 2016 6:09 am Post subject: Kawasaki AR125 Performance Engine Modifications |
Has anybody had any experience in getting more power out of a 12bhp Kawasaki AR125.
I have been told that a big bore kit was available a number of years ago but can't find any more information, I believe his was from Colchester Kawasaki but may have been from a tunner and re sold to Colchester Kawasaki, I have been in contact with them but they have no information to hand.
I have a unrestricted exhaust and will update the carb to 26mm from the 24mm along with the rotary reed modification that I have seen on this and other sites.
Any help or advice will be greatly appreciated
Sean |
Posted: Fri Sep 09, 2016 6:32 pm Post subject: |
Hi Sean, welcome to the forum
Another AR125 fan, that's all we need
Only joking, wouldn't want to offend anyone on the Diff'rent AR's forum
Never owned an Ar125 (must get one to see what the fuss is all about & before all the wheels are sold off) but I have owned bikes with big bore barrels before.
Never again. I would look more towards converting the AR to the derestricted model (A models???) Then go from there.
If I owned an AR then I would make Top shaggy/the cameraman/fazey my best friends.
Hope this helps |
Sean
Posted: Sat Sep 10, 2016 6:06 am Post subject: AR125 Big Bore |
Hi Howie
Thanks for the reply and words of wisdom
I had a AR when I was 18 and regularly got taunted by The RDLC boys because of lack of top end power.
This time I want to re address this issue and put the boot on the other foot
As I don't do hardly any miles on the bikes the reliability up to yet has not been a problem ?
I have a AR80 with 98cc BDK stage 3 tune plus VForce reed block and a hole load of other stuff to make it move, let's say it can hold its own and I thought I would do the same with the 125, but no info on big bore kits and the normal it's not worth the effort.
What bikes have you got
Sean |
Posted: Sat Sep 10, 2016 10:08 am Post subject: |
Hi Sean,
Fair play to you for wanting more top end power, I was trying to do the same to a Kc100 a while back. I failed & sold the Kc to buy parts for my Ns125, which I am also going to try to eke out a bit more oomph.
However, if I remember rightly the Ns125 has the advantage of sharing its engine with the Mtx125/200, so I'm on the hunt for the 200 top end.
I have a few bikes, mainly strokers, the main one being my Kawasaki Kr1, which has most of the good bits from the Kr1s on it. I also have a Kr1s as an ongoing, ongoing ongoing project.
Good luck with the AR, be nice to see what solutions you come up with  |
Posted: Sun Sep 11, 2016 8:28 pm Post subject: |
HI Sean
Been away for a few days..
Yes have tuned AR125s
You can not get a big bore off the shelf nowadays..
Starting with B model 12bhp cdi model with flywheel pick up.
A Disk valve
Good Exhaust
Keep airbox
Vm26 Carb should give you 18/19hp
Then taking to A model spec
Head and barrel almost impossible to find, particularly the barrel. I have a few nos but very reluctant to part with them as I keep them for my own bikes..
Raise exhaust port from 29 to 27mm to top of barrel.
Skim head to reduce volume by 2ml (from 15.5 to 13.5ml)
Skim to A model indicator casting between chamber and engine mounting. Do not change transfers
A Spec as all above 21/22bhp maybe slightly more if exhaust is good. Very drivable and still reliable.
Next suggestions come with health warnings..like all 2Ts
Flow barrel and casings to rris and carb inlet. Cut squish 0.8 with 8mm wide band. Exhaust to 26mm. Gives 26-28hp. Pod filter higher top end power but loses mid range.
Use of 28mm flat slide carb and resonance bottle off rris casing 28-30hp
12-13000rpm. Crank definitely ok up to 12000 under load. (Not had one fail)
Ditto exhaust to 25mm. Reduce transfers by 0.5mm. Use 1-2mm oversize piston. Advance disk timing. Around 30hp +. Very peaky. Can be tedious on the road.
Other suggestions:
Lots of possibilities depending on cash, time, skill (of which I'm limited in all)
Oversize piston and different rod to increase bore / stroke slightly
Eg KR150 piston and Yam rod with thicker Base gaskets. Ditto using KH400 oversize pistons. Seen this done a number of times successfully. Not tried it myself. Gives more mid range potential taking full advantage of rris reeds not top end revs
Possible resleeve (liners are available but never tried this).
Add exhaust valve into top of pipe.. again seen but not tried.
Use ignitech to improve ignition curve.. not seen or tried on AR125 but on my to try list.
Other thoughts??
I know a guy building a top tuned AR125 engine and he's even had a titanium crank made. May not be standard AR barrel once it's finished. It's all very secret this one..
Gearing - finally a really boring suggestion but it's such a cheap and easy way to get the best out of the engine.. one of my AR'S is geared absolutely spot on and pulls really well in all gears. I would be happy lining ut up on the road against many a RD..A to B I think they may just get a shock
Easily available sprockets
Fronts 13 to 17T
Rears 32 to 38T
Keeping airbox sounds boring but it also keeps mid range drive and is easier to set up and more reliable. Airbox mods I can show.
I have lots of pictures I can share for another time. Photobuclet is a pain.
That should be a reasonsble starter for ten anyway
Best
Shaun
How about some pics of your lovely AR'S. . I want to see your alloy swingarm  _________________ We are where we are... |
Sean
Posted: Tue Sep 13, 2016 6:01 pm Post subject: |
Hi Shaun
That is mega info
Do you offer a barrel mod service, if so let me know how much
Really fancy as close to 30bhp as possible.
I am with you on the air box, never seen a bike run correct after removing, if you can send pictures that would be great, as a side note how do you attach a picture as some pictures can be seen and others are via a link.
If you have any NOS parts you want to sell let me know what you have, my mates own ZPower so have raided all they have.
I have emailed a few people about the new liner but nobody has got back to me let, other option will be off to SEP at Derby and see if they can help
Bought a new nos shock from Martyn's in Mansfield but when I got it, it was way different, was going to get one off eBay from China, have you another source.
I have a Nikon with Arrow Can, Micron, Allspeed was going to go with the Nikon to start, the valve sounds interesting, have you got pictures and what does it actually do.
I would think the crank would handel 30 bhp no problem, so not really doing to that expense, we have looked at programmable ignition on the 80 and one of my mates bikes has the BDK kit on I think.
I am going to get carbon reeds, seen sheets of carbon on the net so will get this sorted at work.
Let me know what size shirts you wear and I will print some AR / KR1s ones for you, I sell textile printing and cutting machines, same goes if you need modified gaskets, really handy
I wonder who blabed about the swing arm. Phill ?
Still working progress on this, but will have to get back to it along with the open Clutch window.
The 80 also has gear change indicator and full LED conversion including clock and indicators and rear light, all look as Kawasaki items up till you light them up, that was a nightmare to get correct, it also has Mega bright 3000 lumin head light
Sean |
Posted: Tue Sep 13, 2016 10:53 pm Post subject: |
Hi Sean
Lots of questions will come back to you on.. need to get off the mobile
Generally don't do work for others but help out when I get time.. that said you seem to be very local to me.. I'm near Alfreton - maybe a meet and catch up may be easier sometime
Mechamex did your swing arm..Yes? No it wasn't Phil who told me I've put 2x2 together from people I know
See post link for details of posting pics
http://diffrentstrokers.com/phpBB2/viewtopic.php?t=1587
See updated thread on shock alternatives EDIT _________________ We are where we are... |
Posted: Wed Sep 21, 2016 9:10 pm Post subject: |
Well you set me off so here goes... Spec of AR big bore kit on a budget
Standard barrel can be used
59mm diameter bore
KR150 Wiseco x-lite piston
Head 15cc
9mm squish band
Standard AR con rod
28/30mm pwk carb
15/34 or 14/33 gearing and it will fly
Good power and drivability. Have video of bike running this kit...I just need to find it  _________________ We are where we are... |
Sean
Posted: Thu Sep 22, 2016 11:00 am Post subject: |
Hi Shaun
Looks like I have a expensive shopping list
I guess the piston is the first port of call and then take it to SEP
Please find my email address for the video when you find it
sean@gs-uk.com
Let me know what size tee shirts you want and I will Kawasaki them
Sean |
Sean
Posted: Wed Oct 05, 2016 8:24 pm Post subject: Re: AR125 pictures |
Hope you don't mind, I've put them into my Photobucket so I can post the image files.
Looks very very nice in fast Green
Who covered the seat? They made a good job to replicate the 'period' heat pressed look
Is it the angle of the camera or is that front fairing altered to sit lower over the clocks?
Using standard indicators or going for something Diff'rent ?
Looking forward to seeing this one rebuilt, great stuff mate  _________________ We are where we are... |
Posted: Thu Oct 06, 2016 3:01 pm Post subject: |
That looks fantastic.
Top stuff Sean  |
vestanpance
Posted: Thu Oct 06, 2016 6:34 pm Post subject: |
That looks very clean!  |
Sean
Posted: Fri Oct 07, 2016 9:09 pm Post subject: |
Here you go.. May be worth setting up your own thread for your gorgeous little KHI AR monsters. Liking the rarer colours of your early C model, very nice.
I've also got some front fork braces, have you just fitted one and not put down the dust covers? Got a few genuine Kawasaki rear huggers too  _________________ We are where we are... |
