5-stroke engine
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Petrolhead Chat
PostPosted: Tue Nov 15, 2016 2:06 pm    Post subject: 5-stroke engine Reply with quote
Someone showed me THIS the other day, not something I was aware of. Confused
PostPosted: Tue Nov 15, 2016 9:05 pm    Post subject: Reply with quote
April 1st ??
wizbit
PostPosted: Wed Nov 16, 2016 10:17 am    Post subject: Reply with quote
They are saying they have an extra, low pressure cylinder into which exhaust gas passes from the regular 4 stroke process and extra energy is scavenged from. Does it get power after exactly 5 cycles though?
PostPosted: Wed Dec 21, 2016 4:02 pm    Post subject: Reply with quote
Just watched the video...
So the outer conventional 4-stroke cylinders exhaust in to the central low pressure cylinder every time it hits TDC? There's no firing stroke on the central cylinder, just the burnt gasses from the outer cylinders. How do the spent gasses get out of the central cylinder, is there a third valve that isn't shown in the video?
The exhaust from the central cylinder is critical as that exhaust gas drives the turbo charger.
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Petrolhead Chat All times are GMT
