SDR 200 IGNITION SETTING
frankclock
PostPosted: Sun Sep 02, 2018 5:18 am    Post subject: SDR 200 IGNITION SETTING Reply with quote
I have been wanting to check the timing on my bike
I cannot see any marks on the flywheel can someone point me in the right direction as to what to look for
PostPosted: Sat Sep 22, 2018 8:56 am    Post subject: Reply with quote
Frank,
I think (from memory) I made my own marks on the flywheel and a small dot punch on the side cover gasket face.
I put the dot punch mark in an arbitrary place on the gasket face close to the flywheel periphery where I could easily see it, then (with the cylinder head off), I used a dial gauge to mark the flywheel for TDC and a couple of suitable points on the ignition curve.
With the engine running, it was possible (using a strobe light) to see the ignition timing varying with engine speed.
