| James P
				|  Posted: Fri Jun 14, 2019 1:26 pm    Post subject: |   |
				| Frank,
 When you say "lowdown", do you mean idling only, or at smaller throttle openings also?
 When you say "it clears out", does it eventually do this by itself or only when you open the throttle past a certain point?
 After 'clearing out', will it then idle properly, or does it always run poorly at idle and/or small throttle openings?
 Pending your further advice, some of the following could be responsible:
 Choke/starter plunger not sealing/seating correctly
 Float needle stuck open
 Pilot air jet and/or passage partially blocked
 Pilot air jet smaller than standard
 Also, can you be sure that the pilot jet is actually still 22.5 and hasn't been drilled out by a previous owner?
