thump566
Posted: Thu Sep 04, 2025 9:14 pm Post subject: SDR alternative parts |
I imagine there are numerous Yamaha models that share the same or similar parts.
I recently discovered that the front footpegs of a TZR 250 (3XV) are compatible with the SDR 200. The 3XV pegs are 15 to 20mm shorter and attached to the hanger via a pin with a rivetted end whereas the SDR has a pin with a split-pin arrangement.
Fitting the 3XV pegs creates a much narrower look in keeping with the profile of the SDR. Unless of course you are blessed with large feet ?
https://ibb.co/pBFp9KgS
https://ibb.co/29wh6bw :D |
