ns250r questions
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda
what might the problem be
pistion rings
0%
 0%  [ 0 ]
coil
0%
 0%  [ 0 ]
plug wires
0%
 0%  [ 0 ]
other
100%
 100%  [ 2 ]
Total Votes : 2
ns250rider
PostPosted: Wed Nov 14, 2007 9:36 pm    Post subject: ns250r questions Reply with quote
hey im new to the forum and i recently bought a ns250r mc11 ant the wind screen was broken and so wsa the speedo cable. does anyone know the part numbers or what modles they are like?? also it was working fine and then one day i went to start it and it wouldnt start so i put knew plugs in and thats not the problem. anyone know what the problem might be. i tought it might be the comression but cant out what the compression ratio is sopossed to be?
andy2strokebolas
PostPosted: Thu Nov 15, 2007 11:26 pm    Post subject: Reply with quote
I will pm you the part numbers you need tomorow night.
Andy. Very Happy
andy2strokebolas
PostPosted: Fri Nov 16, 2007 9:43 pm    Post subject: Reply with quote
part numbers as follows
screen 64225-km4-305
speedo cable 44830-kn1-000
ns250rider
PostPosted: Sat Nov 17, 2007 1:12 pm    Post subject: Reply with quote
cool thanks
Alastair
PostPosted: Tue Nov 20, 2007 8:47 pm    Post subject: Reply with quote
A goodly number of bits are the same as the NS400. I scanned the NS400 parts book and a copy can be found at www.ns400r.co.uk along with the workshop manual for the 400 which will give you compression numbers if you use the South african model numbers as the cylinders were common between the SA 400 and the NS250.
Alastair
NS400RF
MTX80RFD
ns250rider
PostPosted: Sun Apr 06, 2008 11:31 pm    Post subject: Reply with quote
ok so now that it is gettin warm enough to work on my bike i found that there was no gas gettin to past the carbs so i took them a part and cleaned them but now it still wouldnt work so i traced the line and the fule pump is messed. i looked on that link but the fuel system only covvered carbs. ive been ookin for about an hour for a owners book online but cant find anything does anyone know of a site i could go to ?
ns250rider
PostPosted: Mon Apr 07, 2008 1:34 am    Post subject: Reply with quote
ok so tonight i was talkin to a guy who has a yzr 1000 and said he had an extra fule pump if i wanted to borrow it to see if it would work and it did. tomorrow im goin to the yammy dealer and orderin one bike is finally workin again cant wait to ride.. still lookin for a owners manual. even if you know where i can order one plz let me know
tyler[/img]
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda All times are GMT
