OLIVERSDAD
Posted: Sat Oct 11, 2008 7:26 pm Post subject: RG250 MK3 AIR BOX AGRO! |
HI ALL, CAN ANYONE TELL ME HOW TO GET THE AIRBOX BACK INTO THE FRAME??? I GOT IT OUT NOT SO LONG AGO AND I SPENT HALF AN HOUR TODAY TRYING TO GET IT BACK IN WITH NO JOY! GRRRRRRR!!!!!!!
THANKS.... |
Craigside_Pete Show Star !
Posted: Sun Oct 12, 2008 12:29 pm Post subject: |
| Try taking out the battery box so you've got more room to feed it in and wiggle it. |
OLIVERSDAD
Posted: Mon Oct 13, 2008 8:37 pm Post subject: |
THE BATTERY BOX AND EVERYTHING ELSE IS OUT. ONLY THE ENGINE IS BACK IN THE FRAME! I GOT IT OUT SOME HOW BUT I'M STUMPED ON HOW TO GET IT BACK IN! I WONDER IF THE BOX COMES APART FOR EASE OF FITTING/REMOVING?
I'LL TRY AGAIN AT THE WEEKEND... |
rg250 screamer
Posted: Mon Oct 13, 2008 9:02 pm Post subject: airbox |
i know you pain buddy i fitted my engine and carbs etc only to find out it should go in before hand, needless to say i now run pod filters!! _________________ PuRE-STRokER |
OLIVERSDAD
Posted: Sat Oct 18, 2008 7:21 pm Post subject: |
GOT THE AIRBOX BACK IN TODAY. IT DOESN'T COME APART EITHER. HAD TO CHISEL THE TOP LEFT FRONT MOUNTING LUG OFF TO GET IT IN. IT IS NOW MOUNTED WITH THE TWO OPPOSITE TOP LUGS ONLY. IT IS SECURE ENOUGH ONCE THE CARB INLETS ARE PUSHED IN. IT AINT GOIN ANYWHERE FOR A WHILE NOW!
STARTED RECONNECTING WIRING AND PUTTING BACK ON OTHER COMPONENTS AROUND AIRBOX AREA. NEW THROTTLE CABLE INTO CARBS AND OIL PUMP. LOOKING ALOT BETTER NOW. DO A LITTLE MORE NEXT WEEKEND... |
Posted: Wed Oct 22, 2008 5:50 pm Post subject: |
Short of taking the barrels off, that was the only way to get it in!! _________________ Breathing new life into an old Gamma!
