Kickstart
Posted: Sun Aug 17, 2008 1:43 pm Post subject: TZR250 1KT Missing Part |
I have a TZR250 1KT model. Bought a few years back and slowly getting the things needed to sort it out.
Pulled the fairings and tank off today and just noticed that there seems to be a pipe missing from the o/s carb. Presume it is the feed for a powerjet. There is a pipe in position on the n/s carb but not the o/s.
Am I right that there should be a pipe there?
All the best
Keith |
dougon2wheels Show Star !
Posted: Sun Aug 17, 2008 10:01 pm Post subject: Re: TZR250 1KT Missing Part |
Kickstart wrote: |
All the best
Keith |
keith,
yes there should be a piped link for the p.j's,they are on my tdr's,and the spare tzr carbs i have.
cheers
doug |
Kickstart
Posted: Mon Aug 18, 2008 9:30 am Post subject: |
Cheers. Just need to source some small enough bore fuel hose.
That cylinder was also a bit down on compression, but no obvious damage to the piston / bore and the blow by past the rings seems about the same on both cylinders.
All the best
Keith |
