TZR 3xv 4FL/HW parts
Flounders
PostPosted: Wed Dec 17, 2008 1:35 pm    Post subject: TZR 3xv 4FL/HW parts Reply with quote
Hello again,
Just an update, I compiled a list of TZR parts if anyone is interested.
Trying to have a bit of a clear out to build something new.....
Parts to fit TZR250R 3XV and TZR125R 4FL/4HW
1 No. Top fairing bracket (fixes under tank) £20
2 No. Brake caliper right hand £35
2 No. Rear light complete £13
4 No. Rear brake light switch £3
3 No. Rear brake reservoir and master cylinder £15
1 No. Rider seat £10
2 No. Speedo cable £7
3 No. Top airbox w/filter £20
1 No. Front brake hose pair £14
1 No. Rear subframe (as new) £40
1 No. Pillion foot rest hangers £25
4 No. Left hand rear set complete £35
Parts to fit TZR250R 3XV only
1 No. Rear set right complete £50
2 No. Gear linkage £6
1 No. Clutch lever £16
1 No. Reedblocks and reeds £20
1 No. Wiring loom (for SP) £50
1 No. Rear brake hose £8
Parts to fit TZR125R 4FL/4HW only
1 No. Two stroke oil tank £20
1 No. Right hand rear set complete £30
1 No. CDI unit £30
3 No. Stop start switch £10
1 No. Top radiator hose £6
1 No. bottom radiator hose £6
1 No. Headlight£27
1 No. Headlight (Brand new) £40
1 No. Left handlebar with 2 weights £10
1 No. Throttle with pair of grips (brand new) £20
3 No. Ignition coil £8
3 No. Regulator £13
2 No. Flasher relay £8
2 No. Throttle cable (new) £22
2 No. Throttle cable £10
5 No. Clutch cable £6
2 No. Radiator £15
1 No. Bottom end stripped (all parts available) £P.O.A.
1 No. Rear brake hose £6
1 No. Oil pump £12
3 No. Reed block and reed£10
1 No. Water pump cover £5
1 No. Sprocket cover (front) £6
2 No. Flywheel generator £45
1 No. Powervalve motor £20
Simon email flounders@talktalk.net
View user's profile Send private message Send e-mail AIM Address
