How do I test my CDI Unit? / RG250 Mklll Wiring Diagram
PostPosted: Sun Mar 29, 2009 5:03 pm    Post subject: How do I test my CDI Unit? / RG250 Mklll Wiring Diagram Reply with quote
Hope someone can help me out here. My longterm project RG250 has reached the point where it should run....and it did, twice for about a second each time!! Now I have no spark?!! The CDi unit is the suspect at the mo, as I cant get a feed to the coil.
Now if I unplugg the CDi, I get what appears to be alternating current at both the Green wire and the Black/Red, nothing at the others. Now if I unplug the 3 Pin connector at the Power Valve (Chamber Control Motor) then I get 8 Volts at the Red/White to the CDi....confusing...
Any help would be appreciated!!
