Trouble removing engine from cagiva mito
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Other Strokers
Drunkn Munky
PostPosted: Tue May 12, 2009 2:56 pm    Post subject: Trouble removing engine from cagiva mito Reply with quote
im having trouble removing the engine from a 92 mito, the bottom engine bolt that bolts through the swingarm aswell wont budge, ive got the nut off and whacked the bolt but no joy. ive been told thats all i need to undo but im starting to have doubts. the bike is stripped so i even have it on its side while i hit the bolt.
Any ideas welcomed Smile
PostPosted: Tue May 12, 2009 3:20 pm    Post subject: Reply with quote
Yes thats the bolt that gives the most trouble.
It is seized solid in the swingarm bearings.
Worst case you have to cut the swingarm.
Good luck
Erik
Drunkn Munky
PostPosted: Tue May 12, 2009 4:05 pm    Post subject: Reply with quote
job done and dont worry i didnt have to cut the swingarm!!!
managed to get hold of a gas torch and heated the offending bolt red hot then all it took was a few whacks with a large hammer Very Happy
PostPosted: Tue May 12, 2009 6:27 pm    Post subject: Reply with quote
Good news
Well done.
Enjoy the Mito ist a great bike.
Should start to rebuild mine
Erik
scorchr6
PostPosted: Tue Aug 09, 2011 12:35 am    Post subject: Reply with quote
what you doing with the mito ? i have a 93 lucky strike
yanw
PostPosted: Tue Aug 09, 2011 3:26 pm    Post subject: Reply with quote
Friends who had a bike shop always used to fit a grease nipple into any swing arm they had off a bike for free.
They figured they might have to take it off again some time...
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Other Strokers All times are GMT
