curryhouse
Posted: Sat May 16, 2009 7:02 pm Post subject: r1 z power valve motor |
| hi the power valve motor has stopped working, when i turn the key there is no movement, its the same engine as the tzr 250, anybody got any ideas what i do next. |
Flounders
Posted: Sat May 16, 2009 7:12 pm Post subject: |
Check you have power at the motor when you first turn the ignition on,
I should have a motor if you need one. |
curryhouse
Posted: Sat May 16, 2009 8:48 pm Post subject: |
hi, when i turn the the key its dead , can i just replace the motor, how do i know if i have power to the motor.
David |
Flounders
Posted: Sat May 16, 2009 8:53 pm Post subject: |
Sounds like you need to check your battery first. Get a volt meter.
Check the current across the terminal for a reading, do the same with it running and compare voltages. Running should give a higher voltage, |
fredjee Show Star !
Joined: 23 Dec 2006 Posts: 133 Location: Derbyshire , England
Posted: Sun May 17, 2009 8:51 am Post subject: |
Sounds a stupid question but when you turn the key and the powervalve motor wont turn is anything working ..... lights .... horn ..... etc ?
If not then your batterys dead ???
My yellow R1-Z drains the battery over a week if left standing its to do with regulator / rectifier but im a tight sod so just diss connect it each time bikes left standing for long periods
Will your bike start ??? If it doe's do you see any movement from powervalve motor then ???
Fred.
PS .... Did you get any joy with your wanted R1-Z stuff from Moriwaki Man or Drewski ???
I just had some stuff from Drewski who brought ..... payed .... shipped within a month direct from Japan and i'm sure he lives in or near Cambridge  _________________ It's never ever finished ! |
