geoffrg
Posted: Wed Apr 21, 2010 5:55 pm Post subject: suzuki rg mk3 |
is there an rg 250 owners forum or club on the net , got a mk3 i think but when i replaced the engine the wires coming from the new engine dont match the connectors on the wiring loom . just wanted to see if anyone has posted video or pics of the wiring . thanks lads |
bobbyboy Show Star !
Posted: Wed Apr 21, 2010 7:07 pm Post subject: |
There's a dedicated RG section on www.rgv250.co.uk.
Good bunch of lads, should be able to help you out.  _________________ www.taffmoto.co.uk for your replacement fairing panels |
geoffrg
Posted: Fri Apr 23, 2010 2:30 pm Post subject: |
cheers bobby its a very good site lots of usefull info , thanks mate |
geoffrg
Posted: Wed Apr 28, 2010 4:32 pm Post subject: |
got another engine for my mk3 gamma cause the old one was knackered, but the wiring and connectors in the new engine are different from the old engine .
the bike was first registered 1/8/87 and the two engine numbers both start with J202 , i have a 3 pin straight connector on the new engine but on the wiring harness on the bike it has a 3 pin T connector any idea,s lads , p,s is there a quick guide to postin pic,s cheers |
Posted: Thu Apr 29, 2010 4:08 am Post subject: |
Not sure but you could have a MK4 engine.
There are a lot of different parts used in the MK4 engine.
Also another stator....
Easy check would be the front sprocket if it has the MK3 plate with the 2 bolts it must be a MK3
The Mk4 has a different counter shaft and uses a circlip for the front sprocket.
Regards
Erik |
geoffrg
Posted: Thu Apr 29, 2010 1:52 pm Post subject: |
cheers erik it is a mk4 motor , the front drive sprocket is held on by a circlip , thanks for the info |
geoffrg
Posted: Wed May 05, 2010 3:55 pm Post subject: |
can i change the stator plate and electrics from my mk3 to my mk4 engine ? , if not anyone know what wires match what , cause they are different colours on the mk4 engine , cheers lads |
