suzuki rg mk3
geoffrg
PostPosted: Wed Apr 21, 2010 5:55 pm    Post subject: suzuki rg mk3 Reply with quote
is there an rg 250 owners forum or club on the net , got a mk3 i think but when i replaced the engine the wires coming from the new engine dont match the connectors on the wiring loom . just wanted to see if anyone has posted video or pics of the wiring . thanks lads
bobbyboy
PostPosted: Wed Apr 21, 2010 7:07 pm    Post subject: Reply with quote
There's a dedicated RG section on www.rgv250.co.uk.
Good bunch of lads, should be able to help you out. Thumbs Up
geoffrg
PostPosted: Fri Apr 23, 2010 2:30 pm    Post subject: Reply with quote
cheers bobby its a very good site lots of usefull info , thanks mate
geoffrg
PostPosted: Wed Apr 28, 2010 4:32 pm    Post subject: Reply with quote
got another engine for my mk3 gamma cause the old one was knackered, but the wiring and connectors in the new engine are different from the old engine .
the bike was first registered 1/8/87 and the two engine numbers both start with J202 , i have a 3 pin straight connector on the new engine but on the wiring harness on the bike it has a 3 pin T connector any idea,s lads , p,s is there a quick guide to postin pic,s cheers
PostPosted: Thu Apr 29, 2010 4:08 am    Post subject: Reply with quote
Not sure but you could have a MK4 engine.
There are a lot of different parts used in the MK4 engine.
Also another stator....
Easy check would be the front sprocket if it has the MK3 plate with the 2 bolts it must be a MK3
The Mk4 has a different counter shaft and uses a circlip for the front sprocket.
Erik
geoffrg
PostPosted: Thu Apr 29, 2010 1:52 pm    Post subject: Reply with quote
cheers erik it is a mk4 motor , the front drive sprocket is held on by a circlip , thanks for the info
geoffrg
PostPosted: Wed May 05, 2010 3:55 pm    Post subject: Reply with quote
can i change the stator plate and electrics from my mk3 to my mk4 engine ? , if not anyone know what wires match what , cause they are different colours on the mk4 engine , cheers lads
