ypvs help needed
chris wilson
PostPosted: Fri Jul 02, 2010 7:08 pm    Post subject: ypvs help needed Reply with quote
i im looking for any advice on a problem im having with my ypvs.
i can only get it to run on 1 cylinder at a time ,if i take any ht lead of and put a plug in that cap the other cylinder will fire ok first or 2nd kick. same when i swap them over but will not run together ,ive put 2 new plugs in in case they were bad but no joy.
any ideas would be much appreciated Crying or Very sad
chubba81
View user's profile Send private message AIM Address
greengoatchoker
PostPosted: Sat Jul 03, 2010 12:44 am    Post subject: Reply with quote
well assuming when you swap the ht lead the problem follows . probably a damaged ht lead or cap not connected to cable properly . that would be where i would start
a pig in the dark is still a pig
chris wilson
PostPosted: Sat Jul 03, 2010 7:02 am    Post subject: Reply with quote
both leeds work independently the left 1 runs with right leed out and a plug on the frame and the right one with left out both give a good spark from the plug thats out and other cylinder runs .
chubba81
