Ignition Unit - MVX250
Dickrod
PostPosted: Sat Sep 18, 2010 10:47 am    Post subject: Ignition Unit - MVX250 Reply with quote
Hi.
I am new to the club.
I own a collection of old Japanese 2 strokes and one of those is a Honda MVX250F. I live in New York and visit my family sometimes each year in N. Ireland and the Honda is stored in N. Ireland so I can ride it a few days each year when I visit. Therefore it does not get much mileage each year, a few hundred at most.
I have heard those bikes have a very bad reputation for blowing rear cylinders. However, I like my MVX very much, it is a fun bike to ride and fast for an old 250, handles well and brakes well and the sound when it comes onto the power is great. I do not ride it full speed for long periods so I have not had any trouble with the rear cylinder.
Here is a friends' web site and on that if you scroll down the page you can see my Honda MVX and a Youtube video of it on the road in N. Ireland from last year. The other bikes on the page are the rest of my collection in New York.
http://derek-beattie.110mb.com/rodney-dickson.htm
I need some parts for my MVX, maybe someone can help ?
(1) - most importantly, I need an IGNITION UNIT for cylinder 2, or the rear or middle depending on what you want to call it. Does anyone have one for sale ?
(2) - clutch plates and springs ?
(3) - front fork tubes ?
(4) - rear seat cowling for single seat conversion ?
Thank You & Best Wishes.
Rodney.
Kawasaki Mach 3
PostPosted: Sat Sep 18, 2010 2:00 pm    Post subject: Reply with quote
I got an MVX single-seat cowl and the optional rad panels from Yahoo Auctions Japan. Best place to find all those parts you need I reckon, not many MVX's around anywhere else.
Front forks may be the same as another Honda from the same era, VT250 maybe ? Confused
Welcome to the forum by the way ! Very Happy
Dickrod
PostPosted: Sat Sep 18, 2010 4:58 pm    Post subject: MVX250 Reply with quote
Hi.
Thank You.
I will check out that site.
Enjoy your bike.
Rodney.
Kawasaki Mach 3
vintage honda
PostPosted: Sat Sep 18, 2010 7:17 pm    Post subject: Reply with quote
hi, i have a mvx in the uk, have been buyng some parts from a guy n german, he has had all the parts you have been lookng for, dont know f they all sold, go to ebay in germany put tem number in 170540351657 , his id on ebay is aerodynamiker .
best of luck. alan
Mr FFF
PostPosted: Tue Sep 21, 2010 4:20 pm    Post subject: Reply with quote
best of luck. alan
So you are the guy who was using bidnapper against me Smile
Fair play though.
I have a various selection of new pistons and rings, but not a complete set yet. Do you have any surplus to sell?
I'm also looking for gaskets of any type
Ian[/img]
MVX250 1983 MVX250 1984 GT380J 1972
Valves are for toilets unless they are power valves.
Claim to fame. Have beeten Casey Stoner over a championship season.
Dickrod
PostPosted: Tue Sep 21, 2010 4:24 pm    Post subject: Honda MVX250F - parts wanted Reply with quote
Hi.
I might have found someone who can repair my Spark Unit.
I need clutch plates and springs and gaskets.
Anyone know were to find these ?
Does anyone make a gasket kit for this bike ?
Rodney.
Kawasaki Mach 3
Mr FFF
PostPosted: Tue Sep 21, 2010 4:40 pm    Post subject: Reply with quote
Clutch friction plates 22201-166-000 £8.51 ea 6 needed available to order from any honda dealer and are in stock with Honda UK. Or part # P22201GF6000 as a japan made pattern part from David Silver at £4:50 ea
166 model code relates to an MB50 so maybe the springs will be the same too.
I haven't found any gaskets anywhere...........yet. But there is always gasket paper available from Frost's on line, your clutch cover a scalpel and hole punch set. Provides hours of fun as the nights draw in. Can you measure the thickness of the original gasket and let me know as this is the route I will be following myself?
Hope that helps
ian
Dickrod
PostPosted: Tue Sep 21, 2010 4:47 pm    Post subject: Honda MVX250F Reply with quote
Thanks Ian.
Good information.
I will let you know about the clutch gasket thickness in due course, but it will be a while until I work again on this bike.
I live in USA and keep this bike in N. Ireland and only ride it / work on it when I visit my family there. It will be Christmas before I am back there.
Best Wishes.
Rodney.
Kawasaki Mach 3
Dickrod
PostPosted: Thu Sep 23, 2010 3:19 pm    Post subject: Honda MVX250F Reply with quote
Hi.
My friend repaired the blown Spark Unit for cylinder number 2.
It worked fine on a test bed but as soon as he fitted it to the bike, it blew again.
Therefore we consider the fault must be in the bike somewhere.
We are focusing in on the Tacho, as this is the only component we have not checked to be good. the Tacho is on the same circuit as Spark Unit 2.
Has anyone any ideas or had previous with the Tacho causing problems ?
Rodney.
Kawasaki Mach 3
Mr FFF
PostPosted: Fri Sep 24, 2010 9:08 am    Post subject: Reply with quote
If you suspect the tacho, try running the motor with it disconnected and see if the problem goes away.
Dickrod
PostPosted: Fri Sep 24, 2010 12:13 pm    Post subject: Honda MVX250F Reply with quote
Yes, that is likely the next step.
I will let you know how that goes.
Rodney.
Kawasaki Mach 3
Dickrod
PostPosted: Tue Oct 19, 2010 3:15 am    Post subject: MVX250F Sark Unit Reply with quote
I got a good used Spark Unit and fitted that and the bike again runs fine.
To be cautious, I hve disconnected the Tacho, I may connect it later and see what happens.
Kawasaki Mach 3
