boney
Joined: 04 Jul 2011 Posts: 8 Location: Sunny Shropshire
Posted: Fri Aug 05, 2011 8:51 pm Post subject: Help!!!! |
My 125lc won't start!!! Went out yesterday and ran fine, came home got changed and wouldn't start! Got no live at coil with ignition on or when it's kicked! Any ideas anyone???? |
bobbyboy Show Star !
Posted: Sat Aug 06, 2011 11:06 am Post subject: |
Start with the obvious first, check the killswitch!
If it ran fine before you stopped, you may have hit it by mistake.
You wouldn't be the first to overlook this, even experienced riders do. _________________ www.taffmoto.co.uk for your replacement fairing panels |
boney
Posted: Sat Aug 06, 2011 2:45 pm Post subject: |
Cheers mate, the kill switch on mine has been disabled and has never worked!!! |
Posted: Sat Aug 06, 2011 3:15 pm Post subject: |
So is it up and running now?
If not, is the ignition switch working correctly, with the idiot lights showing?
Main fuse still intact?
How did you check the coil output? _________________ www.taffmoto.co.uk for your replacement fairing panels |
boney
Posted: Sun Aug 07, 2011 12:28 pm Post subject: |
Not running yet, ignition switch working as it should. Tested the live to the coil with ignition on and when kicked over. Also tested coil feed at cdi and nothing there either. |
boney
Posted: Wed Sep 28, 2011 10:06 am Post subject: |
Been having problems with my RD125lc not starting. I have got power to the coil when kicked over but no spark.
I have tried a brand new coil, different cdi, different stator coil and flywheel, dissconnected ignition switch and cutt-off switch and tested all wires between stator and cdi but still no spark????
I'm going to try thrashing it with a hammer next!!!!!
Read more: http://www.rdnuts.proboards.com/index.cgi?board=advicehelppage&action=display&thread=818#ixzz1ZExfWuV5 |
Joined: 15 Nov 2006 Posts: 1293 Location: Oop North, UK
Posted: Wed Sep 28, 2011 10:15 am Post subject: |
New plug ? |
Posted: Wed Sep 28, 2011 1:09 pm Post subject: |
Squirt some fuel in the air fiter and then try to start it. Try to narow it down to electrics or fuel. All it needs to run is compression, fuel and a spark. _________________ Light is right. |
boney
Posted: Thu Sep 29, 2011 9:34 am Post subject: |
Have tried 2 plugs and it is getting fuel but no spark to burn it. |
Malc
Posted: Thu Sep 29, 2011 5:55 pm Post subject: |
Check low tension wiring - was an issue 20 years ago on LCs so gotta be worth a look? |
boney
Posted: Sat Oct 01, 2011 8:33 pm Post subject: |
If i take the wire off the coil and test it, it has power when the bike is kicked over. When connected back to the coil and then tested there is no power running through it!!!!!!!!!! |
