Mr FFF
Joined: 04 Sep 2010 Posts: 88 Location: West Malling, Kent (Nr Brands)
Posted: Sat Mar 05, 2011 7:59 pm Post subject: MVX250 Re-build is under way |
I've started the MVX250 re build today. loads of fun fitting the taper bearings and powder coated yokes to the powder coated frame.
New bearings fitted to the swing arm, so that will be fitted next
Just waiting for the engine to come back from being ceramic coated
![](http://i1101.photobucket.com/albums/g422/MBX250/IMG_0503.jpg) _________________ MVX250 1983 MVX250 1984 GT380J 1972
Valves are for toilets unless they are power valves.
Claim to fame. Have beeten Casey Stoner over a championship season. |
![](templates/subSilver/images/spacer.gif) |
![](http://www.avatarsdb.com/avatars/foghorn_leghorn_think.jpg)
Posted: Sat Mar 05, 2011 8:47 pm Post subject: |
Quote: |
loads of fun fitting the taper bearings and powder coated yokes to the powder coated frame. |
I take it you are joking?
I love this part of a rebuild though, after all the dismantling, degreasing & prep to the frame ready for the powder coat, its gravy all the way.
Keep the pics coming fella |
trev45
Joined: 18 Dec 2010 Posts: 47 Location: Sydney Australia
Posted: Sat Mar 05, 2011 10:31 pm Post subject: |
Great to see something different and if there are any bits you need let me know
Trev _________________ Racing is for the track, riding is for the road
Both are FUN |
Mr FFF
Posted: Sun Mar 13, 2011 11:00 pm Post subject: |
Todays efforts
Loom, tool and battery box, rear mudguard and light, both CDI boxes and powder coated grab rails
All fasteners have been re chromed, bright zinc or black zinc plated.
The black zinc is awesome on the case screws, kickstart etc. Pics to follow
next week should see the powder coated swing arm, shock and linkage
Trev45, still waiting for your call ![Smile](images/smiles/icon_smile.gif) _________________ MVX250 1983 MVX250 1984 GT380J 1972
trev45
Posted: Mon Mar 14, 2011 8:24 pm Post subject: |
I will do it this weekend, I was waiting for the other bits but they wont be leaving Japan soon so I will back a list for you
Both are FUN |
Mr FFF
Posted: Sun Mar 20, 2011 8:26 am Post subject: |
Yesterdays efforts. Spot the hidden mistake DOH !!!
Lesson learnt........study the pics pre stripdown before re-building
![](http://i1101.photobucket.com/albums/g422/MBX250/IMG_0701.jpg) _________________ MVX250 1983 MVX250 1984 GT380J 1972
Mr FFF
Posted: Sat Apr 09, 2011 9:11 pm Post subject: |
Engine is now back from being ceramic coated. Just got to re-build it now
![](http://i1101.photobucket.com/albums/g422/MBX250/IMG_0814.jpg) _________________ MVX250 1983 MVX250 1984 GT380J 1972
trev45
Posted: Sun Apr 10, 2011 3:50 am Post subject: |
looking good and sent a email today sorry racing season started so busy
Both are FUN |
Darin Show Star !
![Show Star ! Show Star !](images/showstar.gif)
![](http://farm3.static.flickr.com/2723/4122308532_93780b3830_o.jpg)
Joined: 23 Nov 2006 Posts: 444 Location: Isle of Wight
Mr FFF
Posted: Tue Apr 12, 2011 10:37 am Post subject: A Set back |
A bit of a set back. A big one in fact. Despite all thier assurances the company carrying out the re-finishing didn't follow the agreement and instructions to effectively mask everything, with the following results. These are the clutch operating arm bearings. With some luck, I do have these bearings in my parts box, and I'm off to see my engineer Dave Hammond on Saturday to use his skills and workshop to remove and replace them.
I'm gutted, not only because of the set back, but also as this delay will probably mean that I won't be finished by the end of this summer.
I will get there in the end
Just recieved £2K worth of more engine spares. Still looking to swap, deal with anyone on this forum _________________ MVX250 1983 MVX250 1984 GT380J 1972
Darin Show Star !
Mr FFF
Posted: Sat Apr 23, 2011 4:34 pm Post subject: |
Might not seem much, but I have got all my Fork and Brake parts back from ceramic coating, and 1 fork leg is now built with new bushes, seals etc and re chromed stanchions.
Massive relief after the problems they caused with the coating on my engine
Watch this space
![](http://i1101.photobucket.com/albums/g422/MBX250/IMG_0525.jpg) _________________ MVX250 1983 MVX250 1984 GT380J 1972
Mr FFF
Posted: Mon May 30, 2011 10:13 am Post subject: Engine Build |
Great progress this weekend. I have got my cases back from Dave Hammond who has cleaned the insides and replaced the clutch operating arm bearings. Checked and cleaned the gear clusters and changed the input shaft bearing and assembled into case with new oil seal. Brand new crank fitted complete with new end seals and all bolted up. The Black Zinc case bolts look the nuts too. Well worth getting those plated.
![](http://i1101.photobucket.com/albums/g422/MBX250/IMG_0623.jpg) _________________ MVX250 1983 MVX250 1984 GT380J 1972
Mr FFF
Posted: Thu Jun 09, 2011 6:53 pm Post subject: More Progress |
More progress this week.
Leasons learnt......read manual before starting work
Gear shift cover needs to be fitted with engine out of the frame........Doh
![](http://i1101.photobucket.com/albums/g422/MBX250/IMG_0966.jpg) _________________ MVX250 1983 MVX250 1984 GT380J 1972
Mr FFF
Posted: Mon Jul 18, 2011 5:16 pm Post subject: Rear Cylinder |
last Pic was a dry run to make sure water and oil pipes fitted OK. I have a week off so its back out in the shed for a bit of therapy
New rear piston and rings fitted along with the cylinder.
I'm still looking for a front Std piston and a set of 0.25 rings. Anyone? I am prepared to swap in your favour. What do you need?
PS the 18mm piston pin is home made as no gen Honda available _________________ MVX250 1983 MVX250 1984 GT380J 1972
