One for your consideration ts
PostPosted: Mon Feb 17, 2014 9:55 pm    Post subject: One for your consideration ts Reply with quote
http://2strokebiker.blogspot.com/
Does this worktoput pics in?
Ill find out when i press post! If not i promise tostop trying to take shortcuts and do it properly!
Anyhow i like this one it looks like it was made like that, not just thrown together
PostPosted: Mon Feb 17, 2014 9:58 pm    Post subject: Reply with quote
[img]
Is this better?
Ill stop being lazy now i promise![/img]
PostPosted: Mon Feb 17, 2014 11:17 pm    Post subject: Reply with quote
Yep... Like that one Clap Clap Clap
I even like the colour coordinated oil filler cap, grips and headlight etc.. Stuff I usually don't go for. Not sure I'm keen on having to take the spannie off to get at the back wheel tho... But I would cope with it for the style Surprised)
Are you building yours like that? Something similar?
PostPosted: Mon Feb 17, 2014 11:20 pm    Post subject: Reply with quote
Hey just looked again... Is that exhaust held on by anything more than a couple of header springs??
I can see how a bracket could be made to secure it, but I can't see anything at the min?
BRG1200
PostPosted: Tue Feb 18, 2014 8:52 pm    Post subject: Reply with quote
Wow, is that only a little AR50?
applaud the effort. Looks like its still in progress, wonder what the running gear is from?
RZ250 rolling resto
RG250 '84 resto
RD350LC basket case
PostPosted: Tue Feb 18, 2014 8:59 pm    Post subject: Reply with quote
Apparently the running gear is rs 125 front end with old rs 50 rear, the earlier 50s had the single sider along with the af1 which was the 125 before the rs 125
Perfect for converting a tiddler to single sider but the af1 has the chain on the wrong side i believe, thats why they used the 50
PostPosted: Tue Feb 18, 2014 9:01 pm    Post subject: Reply with quote
Thats also why you dont see many trick engined aprillia rs 125s!
Iv thought about it but you only really have the choice of a few engines and the only engine you could really get spares forwas from a bmw!
Again, iv thought about it lol
