		| smokestack
				|  Posted: Fri Jan 10, 2014 4:48 am    Post subject: SDR tyres? |   |
				| What tyres are you guys running on your SDR's I am tyring to order a set but the sizes are causing an issue. The best we can get is a set of Dunlops but the rear would need to be a 120 which I cant see being an issue for clearance. Any suggestions. _________________
 ZZZZZZZZZZZZZZZZZZZZZZZZ
		| smokestack
				|  Posted: Sun Jan 12, 2014 9:20 pm    Post subject: |   |
				| Someone must have bought tyres for their SDR _________________
		| etienne24II
				|  Posted: Mon Jan 13, 2014 10:57 am    Post subject: |   |
				| Hi, I personally rides on road racing and track racing.
 I have lots of possibilities.
 With stock wheels:
 Front: with the stock 2.15" rim: Dunlop KR 364: 85/80/17
 slick tire: Dunlop kr 149: 95/70/17
 Rear wheel: with the stock 2.5" rim: continental TKV 11 110/80/17, perfect grip, but hard to find, and it's a front tire, but doesn't matter regarding the wheight of the bike...
 With an plug and play TZR 125 4FL  rim or TZR 125 4DL rim 3.5"
 you have a lot of choices!
  but you should not get one over 125 width, because there will be a misfit with the front width's tire
 here's an official international table to help you...
 Sorry, it's in French. left :column tire width
 Large column, divided in two: Rim width=> left: radial tyres
 Right: diagonal tyres
 here's some modern really good tyres:
 REAR: K63 100/90 - 17 M/C 55H TL will fit perfectly, and the 110/80 - 17 M/C 57H TL too
 Also the K66 100/80 - 17 M/C 52H TL, but I don't think you'll need rain tyre
 FRONT: K63 90/90 - 17 M/C 49S TT without hesitation!
 You get all theses tyres with a racing compound, called RSW (racing soft Warm), that's just a killing choice...
 http://www.reifenwerk-heidenau.de/modules/reifenliste/view.php?point=2&rtyp=9&PHPSESSID=ki9k2esql3ta3kvg8me0i81d33
 and the american distributor:
 http://heidenautires.com/
		| smokestack
				|  Posted: Mon Jan 13, 2014 7:51 pm    Post subject: |   |
				| Cheers for that, hopefully that information will turn up a result, if not I will just go with the Dunlop with the 120 rear. Must be good fun racing the SDR, I saw a few in Japan fully kitted with RS125 running gear and looking very nice.
		| emzedder
				|  Posted: Mon Jan 13, 2014 7:54 pm    Post subject: |   |
				| Has anyone experience with the Heidenau K40 Front / K39  Rear TT M/C combination - supposed to be very good for track. Been recommended by some classic racers for lightweights, I'm fitting a set to the TA125 rep but 18" rims. They are very reasonably priced too. _________________
 If it don't ring-a-ding-ding it ain't worth a thing
		| James P
				|  Posted: Tue Jun 17, 2014 8:07 am    Post subject: |   |
				| A quick internet search revealed some info on tyres. In each case, I tried to make sure I checked the maker's local (Australian) web-site, so I presume all of these will be available in Australia.
 In the original sizes (90/80-17 front and 110/80-17 rear), the following matched pairs MAY be available:
 Continental GO
 Michelin Pilot Sporty
 Sava MC18 (front size also available in Racing Soft compound)
 Apart from the above, some other makers offered one of the sizes, but not the other. Anyone used the Continental, Michelin or Sava tyres on their SDR?
 As far as I can tell, the SDR's wheel sizes are exactly the same as the TZR250 1KT series (using 100/80-17 front and 120/80-17 rear), so the wheels should accommodate these sizes of tyre. Anyone got any comment on using these sizes of tyre on the SDR?
 Thanks & regards,
 James
		| mboddy
				|  Posted: Tue Jun 24, 2014 11:35 am    Post subject: |   |
				| Whites Racing Products can normally get Bridgestone BT39SS. They are available in 90/80 and 100/80 pair or 100/80 and 120/80 pair.
 I would go for the narrower pair as I like faster steering.
 I have used 90/80 with 120/80 on a street 1KT. Steered nicely.
 Yamaha TDR250, Yamaha TZR250 2XT, Yamaha R1-Z
		| smokestack
				|  Posted: Thu Jun 26, 2014 7:14 am    Post subject: |   |
				| I got Dunlop TT900 GP tyres in the end. 120 rear and 90 front. They look good but I haven't ridden the bike yet so can't comment beyond that. _________________
		| 2TV owner
				|  Posted: Sat Jul 05, 2014 10:00 am    Post subject: |   |
				| my sdr came with a new 120 rear tyre fitted, i thought it should have been a 110 but it looks like its not a common size |  |
		| James P
				|  Posted: Sat Jul 12, 2014 8:35 am    Post subject: |   |
	  | mboddy wrote: |
 Thanks for that Mark - the BT39SS didn't show up on Bridgestone's Australian web-site!
 James
		| mboddy
				|  Posted: Sat Jul 12, 2014 11:07 pm    Post subject: |   |
				| Whites Racing Products do their own importing and can get stuff that the others don't bring in. _________________
