Posted: Wed Oct 08, 2014 10:40 pm Post subject: Doing Declan's AR125.. |
A few pics of the work on one of the kids AR's
Rebuilt front and rear suspension, rebuilt brakes etc...
Lovely new fork stantions... )
Posted: Fri Oct 10, 2014 8:37 am Post subject: |
Repaired OEM headlight unit, painted. Just needs stripes and fitting..
One for the weekend
Posted: Sat Oct 11, 2014 8:30 am Post subject: |
Im not jelous really! _________________ Gagging for it |
Posted: Sat Oct 11, 2014 3:18 pm Post subject: |
Cleaned up a replacement tank to go with the repainted headlight fairing.. Its got a few scratches and dings but solid and doesn't leak like the other one
Look to do up some side panels next..
Posted: Sat Oct 11, 2014 7:37 pm Post subject: |
Has it got twin fuel taps? Or is one blanked off? Seems strange seeing two outlets _________________ Gagging for it |
Posted: Sat Oct 11, 2014 8:49 pm Post subject: |
| Gillinghampaul wrote: |
| Has it got twin fuel taps? Or is one blanked off? Seems strange seeing two outlets |
Yes it does look odd doesn't it.. All the AR125s are the same.
One hole is the fuel tap, the other is the fuel level sensor. They don't have a fuel gauge, just a warning light that comes on and gets brighter as you get low on fuel. The original fuel tap still has a reserve too - so best of both worlds really ) _________________ We are where we are... |
Posted: Wed Oct 15, 2014 6:33 pm Post subject: |
Thanks ts iv been educated!
Anymore little bits a tech i should know about that might convince me to take the plunge? My 80 was definately not technically advanced like that! _________________ Gagging for it |
Posted: Wed Oct 15, 2014 9:59 pm Post subject: |
Anymore little bits a tech i should know about that might convince me to take the plunge? My 80 was definately not technically advanced like that! |
Hmmmm... You don't have to get the screwdriver out to fill up the 2T tank.. Its got a centre stand and not just a 'trick' self returning side stand? Oh and it's big enough for two people ?  _________________ We are where we are... |
Posted: Fri Oct 17, 2014 11:18 pm Post subject: |
Started on the damaged tail fairing tonight... Don't you just know its gonna be more of a challenge when it comes off in a number of pieces.. Hmmmm _________________ We are where we are... |
Posted: Sat Oct 18, 2014 8:29 pm Post subject: |
De dee deeeee de de deeeeeee
Its A TEAM Transformation time...
Ok Hannibal, Sorted leaking Tank, found a new seat, fitted refurbished side panels and front mudguard... It's coming along nicely Murdock..
Refurbished side panels make a big difference..
Seat off eBay, cost all of ten pounds and its immaculate - good times !
Refurbished front mudguard
Its good when a plan comes together ...
Tail fairing needs some work to sort out though.
One for next week fool - as its Stafford Show Sunday so Decs AR on hold
Dee deee deeeee
Posted: Mon Oct 20, 2014 10:35 pm Post subject: |
Tail fairing... Purse... Sows ear..
Work in progress
Posted: Sat Oct 25, 2014 5:08 pm Post subject: |
Rubbed down and painted the rear handrail today.. Needs another coat but way better than the gravel rash and grazed finish it previously had
Posted: Sun Oct 26, 2014 6:00 pm Post subject: |
Repairs completed and couple coats plastic filler primer.
Needs top coats, decals and holes drilling for inner handrail bolts.
Not perfect, but then its only going to be a learner 125 ...probably thrashed to within an inch of its life on every trip to the shops.. Just as the 1980's intended )
Posted: Sun Nov 02, 2014 1:33 pm Post subject: |
Make me one lol _________________ Gagging for it |
Posted: Sun Nov 02, 2014 2:30 pm Post subject: |
| Make me one lol |
I would if you lived closer
Today in between the showers .. Finished the tail fairing and now started the mid panel .. Will load a few pics later  _________________ We are where we are... |
