What AR125 part is this?
PostPosted: Mon Nov 23, 2015 10:55 am    Post subject: What AR125 part is this? Reply with quote
Hi Guys n Gals,
I was just taking a look at the schematic diagram for AR125, specifically at the exhaust, and I found this.
Now it doesn't show on the schematic itself, which just shows the normal parts and is described at a collar.
I was just ensuring that it's nothing that I need?
http://www.cmsnl.com/kawasaki-1989-b6-ar125_model12126/collar_92027102/#.VlLvx6aPSEk
Kindest regards
Reggie
fazey
PostPosted: Mon Nov 23, 2015 11:40 am    Post subject: Reply with quote
just an idea but does it fit on the thread to stop it being damaged.
PostPosted: Tue Nov 24, 2015 12:05 am    Post subject: Reply with quote
Looks like one of the steel inserts that fits into the centre of rubber dampers where the bolts pass through, to stop the damper from being squashed when the bolt is run up EG used on fairings (bellypan base) exhaust muffler hangers etc
