gagster55 Show Star !
Joined: 04 Dec 2006 Posts: 219 Location: West Yorkshire
Posted: Fri Nov 13, 2015 11:24 pm Post subject: |
when I was looking for a Sprint ST speedo, it turned out cheaper to buy a whole instrument console - only £40 plus postage off everyone's favourite auction site..........
included in the comprehensive display of instrumentation is this dinky electronic time piece.....
which I wanted to incorporate into the project - but where could I fit it without it looking like a cheap add-on..............?
here of course - into one of the accessory ports thoughtfully provided by Suzuki.......
a bit of measuring and drilling of 2 holes to accomodate the hour and minute adjustment buttons and......
it's in the r/h panel so at least I will be able to see it when the bike is at rest on it's sidestand  |
jim157
Posted: Sat Nov 14, 2015 9:10 am Post subject: |
What a brilliant project, great stuff! |
Posted: Sat Nov 14, 2015 6:14 pm Post subject: |
frame bending time..........
checking the headstock for accuracy (triangulation of readings taken around swingarm pivot point, upper headstock and lower headstock) using this trick robotic arm thingy, being held by a non-robotic arm........
and comparing the results with the factory data for a GSX1100S frame (same frame as 750)........
that looks close enough - so time to bolt it into the jig and centralise it.........
and take some measurements of the rear subframe (which I knew was twisted)........
which gave us this set of readings........
time to get tough - installing the bracing pieces and the hydraulic jack......
ooh - the tension - the pressure.......
another bout of measuring, some final tweaking and the frame was pronounced straight. Now I can get on with taking the measurements for the rear shock mounts.  |
Posted: Sun Nov 15, 2015 12:18 am Post subject: |
jim157 wrote: |
cheers Jim - glad you're liking it....... |
Posted: Sun Nov 15, 2015 5:50 pm Post subject: |
so - knowing that the frame is now straight, today I set about locating the lower shock mounts onto the 3MA swingarm. The Gazi shocks that I purchased are 300mm between eye centres, adjustable to 310mm max. My ideal measurement is 330mm + adjustment, so the lower shock mounts would have to be moved nearer to the swingarm spindle.
First, I drilled a piece of flat bar with a 10mm hole (lower shock mounting bolt size) and a 12mm hole (top mounting stud size) at 330mm centres, then attached it to the top mounting and jacked-up the swingarm until the lower bracket sat flush on the arm, like so..........
I then sized and fitted the correct bushes for the shock mountings - Gazi shock sets include 4 of each of 3 different-sized bushings - 10mm, 12mm and 13mm.
with the swingarm still positioned at the 330mm height, I fitted the lower mountings to the shocks and attached them to the frame, thus.............
ensuring both lower mountings were sat flush on the swingarm, I took the measurement, both sides, from the trailing adge of the mounting to the end of the swingarm box section - exactly 141mm both sides - result
The swingarm can now go and have the lower mountings welded on, and I'll set about making a new inner bushing for the pivot end to take the smaller diameter Katana spindle. |
Posted: Thu Dec 03, 2015 8:06 pm Post subject: |
they're on...............
Posted: Tue Dec 08, 2015 6:41 am Post subject: |
more treasure from Japan
full lockset - 1 key fits all - spare key included, £23.......
sidestand, spring and bolt for £8........
screen mounting brackets, complete with screws and rubber bushings cost me £7 - the silver screen 0.50p......
reg / rec unit (for show only) £3.50............
full GSX750S1 airbox unit - a bargain £1-50............
Posted: Tue Dec 08, 2015 6:42 am Post subject: |
the rear, air filter section of the airbox after being attacked by a rampant hacksaw.......
and the bit I need, fitted in place, but yet to be cleaned-up - this will disguise the 2T oil tank on the r/h side of the bike.......
Posted: Tue Dec 08, 2015 6:44 am Post subject: |
look away if you are squeamish, or Steve Lucky 7.....................
its not that Steve's quality parts don't fit, just that they don't fit in my case as I want to retain the air filter box. So I have to fit Steve's tray upside-down, like so.....
the holes in the rear of the tray allow access to the bolts that secure the airbox to the frame. As the tray is being fitted upside-down. I also had to drill a hole in each side of the tray to enable it to be secured to the frame with tie-wraps.......
and with the air filter box in place.......
next - I have to cut a hole for the 2T oil filler neck to peek out of........... |
Posted: Fri Dec 11, 2015 1:15 am Post subject: |
back to the clocks - how to make a simple facia for this........
you need Blue Tac.........
a suitable material for the facia (I used some Plasticard)......
a pen............
and a bandsaw helps too........
re-attach template...........
to facilitate final shaping........
out with the compass cutter.........
just needs spraying and a couple of Katana decals and its done........
Posted: Fri Dec 11, 2015 5:27 am Post subject: |
Outstanding job
looks fantastic
keeping the eye on the detail is what realy makes a project stand out
Regards Erik |
Posted: Fri Dec 11, 2015 6:17 am Post subject: |
Hi Gagster,
fabulous work, keep it coming.
Regards
Reggie _________________ Kindest regards
Posted: Sun Dec 13, 2015 6:27 pm Post subject: |
Thanks for the kind words guys !  |
Posted: Sun Dec 13, 2015 6:28 pm Post subject: |
this............
is the 750 Katana airbox inlet trumpet that came with the airbox I bought from Japan, and it just so happens to fit this......
very tightly. And is also an interference fit in here......
so - when its attached to the 2T oil tank neck and fed upwards through the hole in the undertray.....
it becomes an oil-dribble protector........
steezin_and_wheezin
Posted: Mon Dec 14, 2015 3:24 pm Post subject: |
Incredible build!! Looking forward to following along |
