Galaxy Silver R/B B2 Rebuild Project
Goto page Previous  1, 2, 3
AR-jack
PostPosted: Thu Apr 14, 2016 9:33 pm    Post subject: Reply with quote
ninjax wrote:
Build update:
Second question is what screws into the following hole on the frame. Damned if i can remember
cheers
Brian
on the n/s side its the top rear airbox mount although i dunno on the o/s side next to the battery
maybe top shaggy knows?
ar125 a1 1983, ar125 b2 1988, ar125 b4 1988, ar125 b7 1991, kinroad xt50q 2011
XD
jack
AR-jack
PostPosted: Thu Apr 14, 2016 9:38 pm    Post subject: Reply with quote
here a pic of a b2
the orignal one had snapped off so i made one the same as original
it mounts on the top of shock mount and its fixed the the frame
yours may have snapped off?
XD
jack
PostPosted: Fri Apr 15, 2016 12:09 am    Post subject: Reply with quote
Expansion tank fixing
Frame Bracket OS? I will have to check, but it looks like its unused
fazey
PostPosted: Fri Apr 15, 2016 2:23 pm    Post subject: Reply with quote
Frame Bracket OS? I will have to check, but it looks like its unused..
on mine it is the earth to the battery.
PostPosted: Fri Apr 15, 2016 8:58 pm    Post subject: Reply with quote
Hi Ninjax,
great to have another AR125 rebuild coming along.
As for the swinging arm, I had mine powder coated in a metallic gold and it's a very, very close match to the wheels, well impressed.
Kindest regards
Reggie
ninjax
PostPosted: Fri Apr 15, 2016 9:30 pm    Post subject: Reply with quote
looks like i will need to fabricate a bracket for Coolant Bottle.
cheers guys for the info.
much appreciated
AR-jack
PostPosted: Sat Apr 16, 2016 12:19 am    Post subject: Reply with quote
i'll see if i can get anypics for reference
XD
jack
AR-jack
PostPosted: Mon May 02, 2016 7:21 pm    Post subject: Reply with quote
XD
jack
Sean
PostPosted: Fri Sep 09, 2016 3:33 pm    Post subject: AR Big Bore Kit Reply with quote
Hi
Just been reading your posts re the AR125, hope it is all coming together
I noticed that you said in one of these you had a big bore kit 175cc
Did you get this repaired
I am looking for details on a big bore kit for a AR I am restoring
Any information would be greatly appreciated
Regards
Sean
Sean
PostPosted: Fri Sep 09, 2016 3:34 pm    Post subject: AR Big Bore Kit Reply with quote
Hi
Regards
Sean
Page 3 of 3
