Honda Ns125
Goto page Previous  1, 2, 3, 4, 5
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda
PostPosted: Wed Dec 02, 2015 8:52 pm    Post subject: Reply with quote
fazey wrote:
lathe will be first thing though.
Lathe..... Now that will make me jealous Razz
PostPosted: Wed Dec 02, 2015 9:31 pm    Post subject: Reply with quote
Yep, me too.
But a press is my next target, I would love to be able to sort cranks out myself.
It may be a lot to learn but bring it on Dance
PostPosted: Thu Nov 03, 2016 5:35 pm    Post subject: Reply with quote
Ok, after a very busy year, I started work on my Ns engine today.
Had been putting it off because I wasn't sure what I was going to find.
Well apart from a missing RHS crank seal (how it was running without one, I have no idea but it does explain the amount of oil in the crank!), it is in pretty good condition, no bodges, no chisel marks on the cases & everything came apart without too much of a struggle.
However, once cleaned up & ready to put back together I found the new RHS bearing I bought was the wrong size, in the right box but far too big to fit the NS.................aagghhhhh bloody suppliers Evil or Very Mad
New one should be here tomorrow.
PostPosted: Sat Nov 05, 2016 7:52 pm    Post subject: Reply with quote
Bottom end completed today, just waiting on a new piston kit.
Found a couple more problems though. One dowel missing that holds the kick start, stop plate in position, fortunately I had one in my box of spares Very Happy
And a mysterious washer. It was with the idler gear (like most people I like to keep all the parts together in the order they came out) but according to the haynes manual, there isn't a washer under the idler gear No Idea
However there is one under the clutch basket, which wasn't on my clutch basket as removed! I'm assuming the mystery washer is that one Pray
I'm now starting to believe that it is worth having the engine apart on every bike you buy especially if it has the tell tale signs of being apart before Sad
PostPosted: Sat Nov 05, 2016 9:20 pm    Post subject: Reply with quote
I always worry when I've had something apart and on rebuild their seems to be bits left over... Surely people just add things that shouldn't be there and I'm just putting it right... Rolling Eyes Rolling Eyes Rolling Eyes
PostPosted: Mon Dec 12, 2016 3:05 pm    Post subject: Reply with quote
I'm with you there TS Laughing
So, top end on, carb & exhaust fitted, first kick and...................
Fired up Shocked
Not for long though, little bit of tweaking needed on the carb & she is running sweetish......
There is just a faint, not sure how to describe it, 'tinking' sound from the bottom end, I'm hoping it's just a 'bedding' in noise Pray
Any ideas people?
PostPosted: Sat Apr 22, 2017 8:23 pm    Post subject: Reply with quote
Quick update, just because it's a bit quiet on here at the mo.
Haven't done anything interesting i'm afraid, just fired the bike up for the first time in months.
As it is running on premix & auto, that picture does not do it justice
However this is what the 'shed' looked like at the same time
You really have to love 2 strokes Love
PostPosted: Sun Apr 23, 2017 5:18 pm    Post subject: Reply with quote
Love the smell ... who needs a vape when you can just fire up the smoker Smile
PostPosted: Tue Nov 27, 2018 3:59 pm    Post subject: Reply with quote
Really must crack on with the Ns125 Embarassed
Can't believe it's been 18 months since my last update (where does the time go?)
I have in that 18 months sourced a pretty good front mudguard & am waiting on a fuel tap. Just need to justify paying out for an aftermarket screen & seat cover Evil or Very Mad I hate spending money.........
However, I found a bit of piston ring sitting on the engine Shocked I don't think it's from the Ns because I've been fairly busy with customer engine rebuilds & the chances are it came from one of those when I was removing old rings from perfectly good pistons.
But doubt has set in & I think I'll have the top end off just to make sure, I really don't like niggling doubt!
I may even VHT paint the barrel while it's off No Idea
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Honda All times are GMT
Page 5 of 5
