Joined: 15 Nov 2006 Posts: 1300 Location: Oop North, UK
Posted: Thu Apr 11, 2019 9:28 am Post subject: |
No, but you can probably work it out.
Do you have a multimeter, or even a basic continuity tester ? Try it across pairs of terminals in turn, and work out which ones are connected, for each different position of the key. Presumably the switch has off, on, lock and parking-light settings as most do ?
Once you've worked out which terminals do what, you should know where to reattach the wires, based on what's currently not working. |
