What did you do to your bike today ?
Goto page Previous  1, 2, 3 ... 23, 24, 25
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Petrolhead Chat
PostPosted: Sat Apr 06, 2019 5:30 pm    Post subject: Reply with quote
Not had chance to do anything with bikes so far this year, until today. Planned to take a couple out and fire a few others up. Didn't go well...
Batteries were totally dead on the RK and Hornet, despite both being on regular rotation on the Ctek/Optimate chargers. The LC, RB and NSR all fired up, but all pissed fuel out from various places, all need repair work on pipes/taps/carbs.
Crying or Very sad
emzedder
PostPosted: Tue Apr 09, 2019 6:58 pm    Post subject: Reply with quote
A familiar scenario ..... post lay-up blues ...
If it don't ring-a-ding-ding it ain't worth a thing
PostPosted: Mon Apr 22, 2019 7:32 am    Post subject: Reply with quote
Revived the batteries on the Hornet and RK - leaving 'em plugged into so-called maintenance chargers is a bad idea, better to let 'em discharge a bit and then recharge. Took both for a short ride (not at the same time...) and the RK passed its MOT.
Took the carbs off the LC, cleaned 'em, fitted brand-new fuel pipes and clips, also swapped the balance tube for a boost bottle Laughing and replaced the cracked clock surround with a new one. Took that out for a ride.
Swapped the perished fuel pipes on the RB with new ones, not easy as the remote fuel tap has bigger outlets than normal but not much space to play with. Leak fixed, but also discovered a huge crack in the exhaust header pipe probably caused by heat - there's exhaust bandage to stop the aftermarket pipe melting the fairing. Some body panel clips need plastic welding too.
andy
PostPosted: Sat Apr 27, 2019 4:10 pm    Post subject: Reply with quote
Took the 250 Katana for MOT, in the rain Sad first MOT since 2008 Surprised planning to go to Stafford on it tomorrow. Still has the same battery and has never gone flat Shocked
emzedder
PostPosted: Sat Apr 27, 2019 7:03 pm    Post subject: Reply with quote
Re packed silencer with new wadding ... where does it all disappear to? Thought it was sounding noisy!
andy
PostPosted: Mon May 06, 2019 11:52 am    Post subject: Reply with quote
Went to Stafford show on the 250 kat without any problems, but the 1996 Bridgestone BT35 tyres were a bit unpredictable on the damp roundabouts on the A34, think I will get some new ones for the Suzuki track day. Surprised
PostPosted: Mon May 06, 2019 4:13 pm    Post subject: Reply with quote
Hee hee hee, brilliant Andy, got to get your moneys worth! Salute
andy
PostPosted: Wed May 08, 2019 9:51 pm    Post subject: Reply with quote
180 for 2 tyres. 75 for pads fork seals and oil, just being stood still for 10 years. cant believe its been that long.
Post new topic   Reply to topic    Diff'rent Strokers Forum Index -> Petrolhead Chat All times are GMT
Page 25 of 25
