Changing cylinder head from (B) to (A)
SmokerMatt
PostPosted: Thu Mar 05, 2020 3:25 am    Post subject: Changing cylinder head from (B) to (A) Reply with quote
Hi, has anyone tried to have the cylinder head on the (B) version 12bhp ar125 machined to the (A) full power versions specification ?
I have the (A) spec cylinder but the head is Impossible to find anywhere
Any help would be appreciated!
PostPosted: Thu Mar 05, 2020 11:40 pm    Post subject: Reply with quote
Yes.
Easy to machine B head to A standard spec.
Skim head by around 0.3 -0.5mm to marker point in casting. This marker is a raised circle in the casting. Skim down to this point. It reduces chamber volume by 2cc.
Some heads on ebay here. One machined see photo 10/11 (not mine)
https://www.ebay.co.uk/itm/164104276851
SmokerMatt
PostPosted: Thu Mar 05, 2020 11:52 pm    Post subject: Reply with quote
Cheers Top-shaggy, appreciated
I actually found a brand new (A) cylinder on eBay which to honest I thought wouldn't be possible these days.
Thanks for the advice
PostPosted: Sat Mar 07, 2020 12:02 am    Post subject: Reply with quote
Your extremely lucky to find A barrel.
Very very rare nowadays
Hope the rebuild goes well
Very Happy
SmokerMatt
PostPosted: Sat Mar 07, 2020 3:00 am    Post subject: Reply with quote
It wasn't cheap but it's the only one I've ever seen, It's coming from Indonesia !
Cheers for the link for the heads I actually brought them, I'm going to get the (A) head down to the engineering shop and get it fully overhauled so I've got a spare cylinder and head.
The engine dose have to come apart though as the kick start is missing now and again so I need to replace the kick start shaft / gear, probably not a bad idea as she's only done 2000 miles so never been apart, I'll take the opportunity to replace all gaskets that are 32 yeas old.
PostPosted: Sat Mar 07, 2020 11:57 am    Post subject: Reply with quote
Now I'm probably going to get shot down on this but if the crank and seals are ok, why not just do the kick shaft, get it together and enjoy.
If you decide to strip and rebuild to make sure then i completely understand. Got the Tshirt.
Look out for the disk valve, rris O ring and OS crank seal as they are getting harder to find now.
If you get stuck for parts, give me a shout and I will see if I can help Thumbs Up
SmokerMatt
PostPosted: Sun Mar 08, 2020 1:27 am    Post subject: Reply with quote
It's all good your not the first person to tell me not to do a strip down and rebuild, Iv'e got a mate who's a mechanic who told me not to bother doing it until something goes, it wont damage the gear box or engine.
So if I open the engine can you recommend what I should replace if anything ?
Re those parts I didn't know they would be difficult to find, i'll add them to the list !
PostPosted: Sun Mar 08, 2020 6:45 pm    Post subject: Reply with quote
The AR125 is not a complicated engine and nothing you wouldnt check / change in comparison to most others. The rare hard to find bits are in the previous post.
Worth using genuine kawasak piston and rings too. Especially with your nos A barrel
I had a post on here somewhere showing differences on early A and B pistons ... but photobucket has probably knackered that
Let us know how your getting on.
I'm not promoting leaving this site but if your on FB it may be worth also checking AR-125 kawasaki owners group.
Its always great to see another little AR being given a new lease of life
SmokerMatt
PostPosted: Sun Mar 08, 2020 9:04 pm    Post subject: Reply with quote
Cool cheers for the advice, I'm not on face-book but i'll look into it.
Could you just clarify what the rris 0 ring & OS crank seal are because I cant seem to find them with those names on the parts list, I should point out I don't know much about engines, re the crank seal I know that part but what dose the (OS) mean ?
PostPosted: Mon Mar 09, 2020 12:32 am    Post subject: Reply with quote
Dont join FB ... stay clear if you can cope without it
Ahem...
OS was offside crank seal. Its larger than the NS one.. near side LOL
The NS is a common seal size.
Watch ebay sellers because they often send 2 seals the same size and the OS one wont fit
The RRIS seal is a large O ring between the RRIS casing (which houses the disk valve) and the crank casings. If your careful you can refit the old one but it tends to expand when removed and you may have to cut down slightly and glue together. Any leak here and the engine either wont run or run lean.
Most full gasket sets do not include this seal - hence not a full set!
If you cant find these parts I will help you out ok.
DSBBadmin
Site Admin
PostPosted: Mon Mar 09, 2020 6:43 am    Post subject: Reply with quote
Top-shaggy wrote:
...I'm not promoting leaving this site...
No Idea
SmokerMatt
PostPosted: Mon Mar 09, 2020 9:26 am    Post subject: Reply with quote
Cheers for taking the time to explain everything Top-shaggy and the offer to help me out, it's appreciated
Re face book, yes I love my ar's but not enough to sell my soul, I would've just used the wife's account.
Thanks
PostPosted: Mon Mar 09, 2020 11:35 pm    Post subject: Reply with quote
DSBBadmin wrote:
No Idea
Sorry Tim
Im sure you more than anyone understand.
If I could sort photos etc this would be number 1
I suppose it's just too easy on FB
Dam.. I've been rumbled Embarassed
PostPosted: Mon Mar 09, 2020 11:38 pm    Post subject: Reply with quote
Thanks
No problem and its brilliant to have another AR fan on here too.
My wifey would say I've already sold my soul for my ARs.. lol
Keep us in the loop and good luck Thumbs Up
DSBBadmin
Site Admin
PostPosted: Tue Mar 10, 2020 8:53 am    Post subject: Reply with quote
Top-shaggy wrote:
Sorry Tim
Everything we've done - this forum, shows, trackdays - is because we couldn't find anyone else doing it and wanted to fill the gap. If there's another resource that does something better than us, we've always been more than happy to promote it over ourselves. In a perfect world, we wouldn't need to exist at all and I could finally have some time to myself. So, by all means, continue to point people at the most useful place to help them out, whether that's Facebook, an alternative forum or whatever.
Thumbs Up
