Joined: 31 Mar 2013 Posts: 193 Location: Sydney, Australia
Posted: Thu May 16, 2024 1:08 am Post subject: |
| thump566 wrote: |
I was also planning to install a tacho as outlined in JamesP SDR rebuild but discovered the drive parts were now NLA. That went out of the window until I spotted an SDR parts bundle on eBay and snagged them for a Greek breaker . The bundle included the NLA parts and I have now ordered the other items from a UK Yamaha dealer plus finding an instrument panel in the UK of an SRX400 which has the OEM tacho to migrate across.
What a bit of luck finding all those bits together! Although it seems likely that the SRX400 tachometer will indicate correctly, I see that its scale only reaches to 9000rpm. Hopefully the tacho will have 1000-1500rpm of 'over-rev' capability without sustaining any damage, so as to enable full use of the SDR engine speed range if desired.
It was also fortunate that the crankshaft webs were salvageable. I was intrigued by your comment about turning down the rotor-side journal on account of rust pitting and using a DT200 oil seal. I had thought that all DT200 models used the same rotor-side oil seal as the SDR - please let us know if there is anything further to tell on this point.
Good work in cleaning up the reed stops - will you apply any coating to prevent future rusting? On occasion when I have found reed stops in a condition like yours, I have taken them for re-zinc-plating.
Will look forward to more images and info in due course!
thump566
Posted: Wed Jul 31, 2024 9:03 pm Post subject: |
I have called it a day cleaning the chassis and refitted the stem after checking and overhauling the bearings. I'm not looking to produce a garage queen that rarely sees daylight, its planned at being used albeit infrequently.
I've taken the front suspension apart and discovered there is no oil in the forks either - guessing the fluids are removed before shipping? Consequently the internals weren't in good shape but the necessary replacements are still available. (Even the brake hoses were empty).
Am planning to replace/update the engine mountings and currently reviewing what shocks are available as replacements.
It was never planned to be an overnight rebuild but looks like a much longer job than expected. Oh well. |
Posted: Mon Aug 05, 2024 7:56 am Post subject: |
Thanks for helping to keep this place alive !  |
thump566
Posted: Wed Sep 11, 2024 5:57 am Post subject: |
It never rains but it pours.....
The Valter Moto workshop stands have finally arrived together with a lightweight rear stand (the spindle will need addressing to fit the small diameter hollow axle of the SDR). However the Mancave is not accessible now for several weeks whilst some building works is in progress.
Maybe I can prep items in the shed temporarily, things like pressing the new crankcase bearings etc. |
Posted: Fri Sep 20, 2024 6:32 am Post subject: |
| thump566 wrote: |
| Maybe I can prep items in the shed temporarily |
Or the house...
thump566
Posted: Sun Oct 13, 2024 6:54 pm Post subject: |
| Vacation over, need to straighten out the garage and crack on. |
thump566
Posted: Mon Jan 13, 2025 7:57 am Post subject: |
The Valter Moto workshop stands eventually arrived from Italy but the SDR was gazumped when another Stroker got to them first. The stands are used by a dealer I know in their own workshop so came recommended and to be fair are pretty solid.
The SDR is taking a much longer time to resurrect than hoped bt then thats usually the case with most projects. - I reckon another 6 weeks overhaulling the suspension on the other Stroker then the SDR rebuild can hopefully start. |
Yellow02Z06
Joined: 14 May 2023 Posts: 21 Location: Michigan, USA
Posted: Tue Jan 14, 2025 1:11 am Post subject: |
| thump566 wrote: |
Ok, the trellis frame is like a mini Forth Bridge, at least it feels like it whilst cleaning it up.
The refurb progress took a hit as I was away for 4 weeks although a bundle of bits was waiting on my return, hopefully the package contains all the items for the DT200R speedo drive mechanism plus the cable.
I have ordered a workshop stand to use whilst both front and rear end remain off the bike which will hopefully be useful as the re-assembly progresses. Yes I could have made my own stand but there is currently a long list of jobs and the stand would have been yet one more.
To be continued ... |
How goes your project? I responded as to you question re what I did with my frame in my thread...
As I mentioned there, I have just been riding mine....
I do keep thinking of modding it, or getting another (I know where one is) and modding it....thoughts include a Beta 300 engine swap (I have a 2024 Street Legal Beta Dirt Bike), or a 3XV V-Twin Yamaha.... _________________ 1971 Kawasaki A7 350 Avenger (stock)
1973 Kawasaki H1 500 (mild mod)
1975 Suzuki GT250 cafe racer
1985 Yamaha RZ350 (mild mod/blue)
1987 Yamaha SDR200 |
thump566
Posted: Wed Jan 15, 2025 9:18 pm Post subject: |
| Yellow02Z06 wrote: |
| thump566 wrote: |
2024 Street Legal Beta Dirt Bike), or a 3XV V-Twin Yamaha.... |
The project got derailed somewhat but hopefully will get kick started again soon. As I mentioned earlier in this thread, the engine was a mess when I bought it so took more time to sort prior to starting the rebuild.
I haven't ridden my SDR at all yet so can't comment on a modded one, however I would recommend a 3XV if you manage to find a good one. Looking at your garage, a 3XV should be the newest of your bikes and the chassis/handling will definitely be a welcome addition I would hope. They are amazing. |
thump566
Posted: Wed Jan 29, 2025 8:15 am Post subject: |
Alternative part option for difficult to locate items....
The SDR 200 (2TV) chain guard 2TV-22311-00 has an updated part of 3XV-22311-00 which belongs to the TZR250R 3XV.
The 2 parts are very similar aside from the top edge towards the front sprocket. The mounting holes even line up :D
If you are trying to source the SDR item then the 3XV guard could be an option albeit both are now listed as NLA.
https://ibb.co/dw2SWCxf
https://ibb.co/bRFpwj2G
https://ibb.co/b54vydQH |
thump566
Posted: Sat May 24, 2025 8:51 pm Post subject: |
| Can anyone point me to where I can order an engine gasket set please? |
Posted: Mon Jul 07, 2025 12:13 pm Post subject: |
| thump566 wrote: |
Ron,
I think that nearly all of the gaskets are still available from Yamaha (at least they were fairly recently). If you want an aftermarket set, you can use many of the gaskets from a set intended for the 2RH-based TZR125.
thump566
Posted: Mon Jul 07, 2025 6:45 pm Post subject: |
| Many Thanks James. I have just received a gasket set, front engine bolts, fork seal kit , fuel petrol tap kit and air filter kit from Japan. Hoping to receive a replacement fuel tank in the next couple of weeks. The engine build should now begin shortly I hope. |
thump566
Posted: Mon Aug 04, 2025 8:40 pm Post subject: |
Having sourced a plethora of gaskets, bearings and oil seals, the rebuild having stalled for some time, has finally commenced.
https://ibb.co/W483sf4y |
Posted: Thu Aug 07, 2025 6:21 pm Post subject: |
Thank goodness for you SDR boys, keeping this place alive.
