		| chris wilson
				|  Posted: Fri Jul 02, 2010 7:08 pm    Post subject: ypvs help needed |   |
				| i im looking for any advice on a problem im having with my ypvs. i can only get it to run on 1 cylinder at a time ,if i take any ht lead of and put a plug in that cap the other cylinder will fire ok first or 2nd kick. same when i swap them over but will not run together ,ive put 2 new plugs in in case they were bad but no joy.
 any ideas would be much appreciated
 chubba81
		| greengoatchoker
				|  Posted: Sat Jul 03, 2010 12:44 am    Post subject: |   |
				| well assuming when you swap the ht lead the problem follows . probably a damaged ht lead or cap not connected to cable properly . that would be where i would start _________________
 a pig in the dark is still a pig
		| chris wilson
				|  Posted: Sat Jul 03, 2010 7:02 am    Post subject: |   |
				| both leeds work independently the left 1 runs with right leed out and a plug on the frame and the right one with left out both give a good spark from the plug thats out and other cylinder runs . _________________
 chubba81
