wolfman
Posted: Thu Mar 31, 2011 10:57 am Post subject: Crank Rebuild On mk 3 250 Gamma |
hi
Can any of you guys recommend a company to rebuild my crank and a rough estimate of cost? .The engine is my next stage of resto and need 2 x pistons , rings , pins ,little ends ,seals and bearings also. _________________ Riding a two stroke is sometimes like buying a one way ticket!!!!! |
Posted: Thu Mar 31, 2011 8:10 pm Post subject: |
sorry don't know about the crank.
haven't done one ..yet.......
But i would go for the genuine Suzuki pistons etc.
They are on Ebay at the moment i thought for 28 GBP a 0.50 Mk 3 piston.
All the parts you need are still available new from Suzuki but not cheap.
Regards Erik
11210-40A05-OFO piston standard
11210-40A05-050 54.5 1st oversize
11210-40A05-100 55 2nd oversize
12140-40A10 ring set std
12140-40A10-050 1st
12140-40A10-100 2nd
12151-07000 pin piston
09381-14001 circlip
09263-14019 bearing piston pin
09263-22034-OCO bearing crank pin
09262-25036 bearing r/h
09262-25056 bearing m
09262-25056 bearing l/h
09289-32004 oil seal r/h
09289-33008 oil seal m
09283-25080 oil seal l/h
12161-14500 connecting rod |
wolfman
Posted: Thu Mar 31, 2011 8:34 pm Post subject: |
Thanks for that info Eric , i don't know if my budget will stretch as far as all genuine parts. _________________ Riding a two stroke is sometimes like buying a one way ticket!!!!! |
Mr FFF
Posted: Thu Mar 31, 2011 9:08 pm Post subject: Cranks |
I have been using the same guy for over 10 years. Dave Hammond of DHRRacing 01304 829829. Tell him Ian Read recommended you.
You can use pattern parts, but the quality isnt the same and they wont last or perform as well.
The last job he did for me was a GT380 crank. I supplied the parts and he charged £70 for the strip and rebuild of the crank. A twin should be about £50 plus parts _________________ MVX250 1983 MVX250 1984 GT380J 1972
Posted: Fri Apr 01, 2011 5:19 pm Post subject: |
P J Motorcycle Engineering did my Gamma crank and rebore. Cant fault themm highly recommended _________________ Breathing new life into an old Gamma!
