Xebastian
Joined: 04 Jan 2012 Posts: 4 Location: Argentina, Buenos Aires
Posted: Fri Jan 06, 2012 2:42 am Post subject: My new punished MVX250F |
Hi all!
i'm Sebastian from Argentina, another lover of the bikes since I Have use of reason.
At present I have a Honda VF750C 83, Honda Tornado (XR250 Brazil) and the newcomer MVX250F, but years ago I always had two-strokes bikes (Kawasaki GTO110 and Jawa TS350 among other national made 50cc bikes) and the mvx simply left me speechless in quality and power. The problem is that the bikes in this country are the most handled the unskilled owners or mechanics and this bike regrettably follow the same destiny.
For example, at some point in ther lives someone bridge the two front exhaust outlets with a pipe and modified the two silencers to make it as in a twin four stroke.
I also had to pull out the engine to weld the frame because they forgot to put a hub or something on the bottom screw and when tightened it broke in two points.
The list goes on but slowly I regain the bike.
Greetings from Buenos Aires and scuse my poor english. |
Joined: 15 Nov 2006 Posts: 1300 Location: Oop North, UK
Posted: Fri Jan 06, 2012 9:36 am Post subject: |
Welcome Sebastian ! Another MVX250F owner - very pleased to see more of these appearing on here.
Good luck with restoring your bike, we like to see photos too.
And your English is fine, better than some others on here...  |
colp
Posted: Fri Jan 06, 2012 9:25 pm Post subject: |
welcome, and your english is better than my argentinian !
even though i support manchester city football club here in england with pablo zabaleta and sergio aguero in the team (we don't mention carlos tevez anymore!) _________________ just do it |
Posted: Sat Jan 07, 2012 12:23 am Post subject: |
Or Diego Maradona !
(sorry I'm showing my age...)
Welcome to the forum and bike looks like a good project - like that model !
Keep us up to date with progress
Darin Show Star !
Joined: 23 Nov 2006 Posts: 444 Location: Isle of Wight
Posted: Thu Jan 12, 2012 11:55 pm Post subject: |
| Darin wrote: |
Welcome to Diff'rent Strokers Sebastian
Hope you enjoy your new toy - it looks great from here! I can't believe there's ANOTHER MVX on here now - they're almost as common as RG250s!!  |
COMMON!!!????  _________________ Breathing new life into an old Gamma!
Xebastian
Posted: Sun Feb 19, 2012 3:31 am Post subject: |
Thanks to all for the welcome!!
Now I disassemble the cylinders for a compression leak and I found some new surprises, new adapted front pistons and the rear original with big clearance. I had to change the rear piston and I'm crossing my country to see who can forge to me. |
Mr FFF
Posted: Sun Feb 19, 2012 11:19 am Post subject: Rear piston |
What size do you need as I have loads of rear pistons _________________ MVX250 1983 MVX250 1984 GT380J 1972
Mr FFF
Posted: Sun Feb 19, 2012 2:29 pm Post subject: MVX parts |
I have a kick start lever and I can do you a complete rear piston kit
0.5mm Piston
0.5.. ring set
piston pin
bearing
2 x circlips
I can do all the gaskets apart from the aluminium cylinder head
Let me know what you want
Will post to overseas
Regards
Ian _________________ MVX250 1983 MVX250 1984 GT380J 1972
