TheNewGuy
Joined: 12 Oct 2012 Posts: 58 Location: Ashington, Northumberland
Posted: Thu Oct 18, 2012 11:39 am Post subject: |
| StrokerBoy wrote: |
| Gillinghampaul wrote: |
| The little ysr is much like the ar though in that no one really caters for them online but it is a two stroke so here i am! |
There's a dedicated UK Gag Bike Forum but it's pretty much dead these days.
I was asked to take it over, but I have far too much on my plate already. |
Hehe i would love to try a gagbike. at 6ft8" and 16.5st it should be a funny sight to see..  _________________ Current bikes
ar125
fj1200 |
Posted: Thu Oct 18, 2012 1:05 pm Post subject: |
Hey I'm not far off your size fella and I look like I'm riding a gag on the AR...
Hurry up and get your little AR up and running, I wanna see the pictures
TheNewGuy
Posted: Fri Oct 19, 2012 8:00 pm Post subject: |
| Top-shaggy wrote: |
still no barrel yet i am off work tomorrow too so i cant get it untill monday lol, hopefully i will get it up and running by next friday/sat.. if the conrod comes too  _________________ Current bikes
ar125
fj1200 |
TheNewGuy
Posted: Tue Oct 23, 2012 8:20 pm Post subject: |
well i got the barrel and bored it to 56mm, got it back on the engine. great compression, hopefully get it started by friday/sat  _________________ Current bikes
ar125
fj1200 |
Posted: Tue Oct 23, 2012 8:29 pm Post subject: |
Can't wait to see your little AR up and running TNG
Did you have to weld the stud mount or has it held ok?
TheNewGuy
Posted: Tue Oct 23, 2012 8:44 pm Post subject: |
its head on fine, but i am thinking of just making a stud, then welding over the crack, i'll see what happens, i just want to get it up and running first
cheers again for the barrel  _________________ Current bikes
ar125
fj1200 |
Posted: Tue Oct 23, 2012 9:16 pm Post subject: |
No probs TNG
FYI the tank cap lock barrel is the same as the tail flap lock - what I'm trying to say is that they are interchangeable. If your careful you should be able to pick the lock as long as the key isn't snapped off.
Unfortunately I don't think they are available from Kawasaki and no one makes a copy. If you get them open, it's easy to take out (or adjust) some of the lock slides that fit the key to make it easy to open and close using the new ignition barrel key (I've done this more than once myself )
If the chrome key cover (round bit at the top where the key goes in) is damaged it can be repaired if your really careful. I've also done this more than once. You can only do this when the lock barrel is out of the cover(s)
Let us know how you get on, will help where I can ok
TheNewGuy
Posted: Thu Oct 25, 2012 7:16 pm Post subject: |
| Top-shaggy wrote: |
No probs TNG
the battery is on charge.. but does it need a charge if its got a kick start?, i know it seems like a silly question. but i have never even used a 2 stroke ... never mind try to fix one  _________________ Current bikes
ar125
fj1200 |
TheNewGuy
Posted: Thu Oct 25, 2012 9:26 pm Post subject: |
seems legit, so its a capacitor?  _________________ Current bikes
ar125
fj1200 |
Posted: Thu Oct 25, 2012 9:44 pm Post subject: |
| TheNewGuy wrote: |
seems legit, so its a capacitor?  |
Yep - and if I knew want I was doing I would build one... But I don't
Never had one fail on me but I have been told that when they do they can go with a bang...
So I stick to what I know works  _________________ We are where we are... |
TheNewGuy
Posted: Fri Oct 26, 2012 3:42 pm Post subject: |
the battery was quite past it, i have added some sulfuric acid and i will try charging again. hmm.. Also New upside down forks came to replace the rust rods. little bit of tweeking needed but i will make it fit.  _________________ Current bikes
ar125
fj1200 |
Posted: Fri Oct 26, 2012 7:25 pm Post subject: |
| TheNewGuy wrote: |
the battery was quite past it, i have added some sulfuric acid and i will try charging again. hmm.. Also New upside down forks came to replace the rust rods. little bit of tweeking needed but i will make it fit.  |
C'mon TNG share the love... Lets see some pictures of how your getting on  _________________ We are where we are... |
TheNewGuy
Posted: Fri Oct 26, 2012 9:08 pm Post subject: |
Sorry my lass is ill at the moment, had to heed to her every need tonight
got my mate doddy coming tomorrow so i WILL make progress
and attach these bad boys..
Peeps may think i am modding this to much, but i dont care cause its still a 2 stroke at heart.  _________________ Current bikes
ar125
fj1200 |
Posted: Fri Oct 26, 2012 9:20 pm Post subject: |
On the contrary TNG I think people on here will think its great your making the AR what you want it to be. That's the essence of this site Diffrent' and not many rebuild ARs ... Even less build trick ones - soooooo please don't give up on the, I'm really looking forward to seeing how it goes
What bike are the USD forks off and what wheels are you thinking of using? _________________ We are where we are... |
