		| Ibby4585
				|  Posted: Mon Dec 17, 2012 11:41 am    Post subject: |   |
				| Hi.
 I've binned the old caliper bracket as it looked awful. I've managed to buy a factory gild bracket from Japan, it will fit my brembo caliper and my EBC prolite I have.
 Kris
		| 2TV owner
				|  Posted: Mon Dec 17, 2012 7:32 pm    Post subject: |   |
				| Hi Kris,
 How did you find the caliper bracket from Japan, was it expensive to ship/buy?
 Justin
		| Ibby4585
				|  Posted: Mon Dec 17, 2012 8:33 pm    Post subject: |   |
				| It was on yahoo Japan auctions. I buy quite a lot of stuff on there, it was second hand but in very good condition, worked out at £42.00 expensive I know, but worthwhile.
 What sort of state is your Sdr in then mate? Got to be better than my pair!
		| 2TV owner
				|  Posted: Tue Dec 18, 2012 10:15 pm    Post subject: |   |
				| Hi Kris,
 Can't get my head round the Yahoo Japn auctions
 My SDR is quite good or at least i think so! Its the same colour as yours (green, not black as the log book says) Its all really standard, i got it in Feb this year from a place in london. Was one of those bikes that I always said i would own.
 I had a  problem with it pretty much straight away when i got it on the road, it'd had the carb rebuilt and according to the guy who delivered it also the engine had been rebuilt, it sounds sweet and is only showing 8000k on the clock. It developed a fault where it wouldn't pull the skin off a rice pudding on the flat or up hill but would go like stink downhill. After a lot of wiring checks and a replacement cdi i narrowed it down to the power valve ecu. It's all on here!
 I ended up getting an ignitech programmable power valve ecu from Ignitech, its a good piece of kit, it still needs a bit of tweaking but it transformed the bike until the end of September when it started playing up again.
 After a bit more testing i came to the conclusion that the power valve servo was slowly giving up the fight and i think that is what caused the original ypvs ecu to fail. I got a second hand one from Ebay, they are the same as a 1KT TZR250 as they have an extra lug that houses a cable that pulls the oil pump open when the power valve works it seems to have sorted it out. It's just sat at work now over the winter and i'm just playing with the front disc but need to fab a bracket to house the caliper. I'm also toying with getting the wheels powder coated as  they are in original condition but could do with a bit of a refurb.
 Don't know f you have ridden yours yet but you wont be dissapointed
   I'm an auto electrician by trade and have spent hours going over the wiring diagram when mine was playing up so if you need any help with wires just let me know.
 Justin
		| Ibby4585
				|  Posted: Wed Dec 19, 2012 12:54 am    Post subject: |   |
				| No, not ridden mine yet. Well either of them actually. I just got number 1 going after a nightmare with the electrics, then the winter weather set in so its on the back burner until feb, march time.
 Just using winter to collect a few bits for my spare bike. I'm desperately trying to locate a good tank but if I can't I will have to fork out for an alloy Beater tank, but at £1100 quid they cost more than the bikes!!
 I still have electrical problems on mine so I may call on you at some point.
 Kris
		| Kickstart
				|  Posted: Tue Dec 25, 2012 9:08 pm    Post subject: |   |
				| Hi
 With the Yahoo auctions it helps to search for the model code rather than the normal name (ie, 1KT for an early TZR250).
 All the best
 Keith
		| Sdrman
				|  Posted: Wed Jan 16, 2013 7:47 pm    Post subject: |   |
				| Other problem is the fuel taps act up, and blocked fuel filters
 I'm making replacement fuel filters and fuel tap kits
		| 2TV owner
				|  Posted: Wed Jan 16, 2013 8:21 pm    Post subject: |   |
				| there is someone on fleabay doing the fuel tap rubber seal repair kits, they don't list the sdr tho you have got to email them but they do do a kit. will be ordering one for mine. |  |
		| Ibby4585
				|  Posted: Wed Jan 16, 2013 8:56 pm    Post subject: |   |
				| Have you got the link please?
 Kris
		| 2TV owner
				|  Posted: Wed Jan 16, 2013 10:23 pm    Post subject: |   |
				| Hi Ibby,
 Cant get the link to work but if you type in this ebay item number it will bring up an XT500 listing, send them a message asking if they do one for an SDR and they should come back to you with the details, they have a shop GPM classics. Not ordered mine yet but i asked them how come the SDR one was £4 more than the XT one, work than one out!
 120914527083Item number:
 Justin
		| StrokerBoy Show Star !
				|  Posted: Wed Jan 16, 2013 10:36 pm    Post subject: |   |
	  | 2TV owner wrote: |
	  | Cant get the link to work but if you type in this ebay item number it will bring up an XT500 listing, send them a message asking if they do one for an SDR |  http://www.ebay.co.uk/itm/120914527083
		| Ibby4585
				|  Posted: Thu Jan 17, 2013 8:29 am    Post subject: |   |
				| Thanks guys. |  |
