crm250 Show Star !
Posted: Mon Oct 01, 2012 7:38 pm Post subject: Bought my old KSR80 back |
Should never have sold it.
Imported a 2001 KSR80 back in 04 and it was a really usable bike. for some reason i sold it in 2007 - 2008 for next to nothing, and after passing through a few "hands" i spotted it on ebay and made an offer - and now have it back.
Well so much for caring owners, someone has decided to "upgrade" the tail light assembly with some aftermarket shite, aftermarket levers that dont fit and keep the front brake on. blowing exhaust, and in general abused conditon with bits missing.
So looking forward to getting it back into a usable condition and having fun on it again.
Need to source some levers, mirrors, a top end gasket set and of course a tail light and undertray. |
Terminaterre
Joined: 25 Jun 2009 Posts: 105 Location: Wavre / Belgium
Posted: Mon Oct 01, 2012 7:42 pm Post subject: |
The cylindre head gasket and expansion gasket are stil available (at least last year). Base gaskets are NLA.
I'm not sure but I think I've got a tail light and undertray  _________________ NS400R, YSR50, YSR125, Banshee, TDR250, KTM 500MX, Bimota V-Due, TDR80, Harris Rotax 250... |
crm250 Show Star !
Posted: Wed Oct 03, 2012 6:16 pm Post subject: |
wow thanks, dont suppose you have part numbers do you please ?
i will try and order some from somewhere.
i read this motor is a KDX 80 engine, anything else share this motor ? or other parts transferable ?
am going to try and get a shock for the 110 and see if it will fit.
Paul |
crm250 Show Star !
Posted: Wed Oct 03, 2012 6:18 pm Post subject: |
infact if you have part numbers for pistons and rings and small ends so i can to a top end refresh please. |
Terminaterre
Posted: Wed Oct 03, 2012 10:25 pm Post subject: |
I've got a parts-list and a workshop manual (in japanese ).
I'll scan the engine section for you but, if I remember correctly, pistons are NLA. I put a Polini piston originaly designed for a Piaggio scooter in mine (needs a thicker base gasket). _________________ NS400R, YSR50, YSR125, Banshee, TDR250, KTM 500MX, Bimota V-Due, TDR80, Harris Rotax 250... |
crm250 Show Star !
Posted: Thu Oct 04, 2012 12:08 pm Post subject: |
That would be a great help and thanks.
if you want to mail it directly my email is paul at crm250 dot com
Cheers |
Terminaterre
Posted: Thu Oct 04, 2012 9:55 pm Post subject: |
Sent  _________________ NS400R, YSR50, YSR125, Banshee, TDR250, KTM 500MX, Bimota V-Due, TDR80, Harris Rotax 250... |
crm250 Show Star !
Posted: Sun Jan 13, 2013 6:06 pm Post subject: |
just revisting this, got the bike back home today and so far so good.
the aftermarket tail can easily be swopped with the OE one - same with indicator lenses.
levers are all sorted
bike scrubbed up well but it does need some bits
the throttle cable feels bad, cable is frayed and looking poor at the top so needs a new one, also the twistgrip looks in bad shape too.
chain looks like its been in the sea.
sprockets look ok but will replace anyway
the air intake side of the carb - snorkel is rock hard and needs replacing.
mirrors are missing so need to source some nice ones to suit.
dont suppose you know what size exhaust gasket these use would you ?
Cheers |
Posted: Sun Jan 13, 2013 8:48 pm Post subject: |
There was anarticle in last months practical classics about refurbishing rubber components, making them soft and like new again, ill try and dig it out for you and get the info, maybe rescuethe snorkel as ill bet they are not easy to come by! _________________ Gagging for it |
crm250 Show Star !
Posted: Sun Jan 13, 2013 9:02 pm Post subject: |
cheers, i put it on the radiator and warmed it and it was lovely and pliable once again, however by the time you get it to the garage - brittle again
unless i fit it in summer lol. |
Posted: Sun Jan 13, 2013 9:06 pm Post subject: |
Its a solution you gently warm it in and it stays nice and bendy just like new! _________________ Gagging for it |
Posted: Sun Jan 13, 2013 11:24 pm Post subject: |
Go on crm250' have you got any pictures for us  _________________ We are where we are... |
Terminaterre
Posted: Sat Jan 19, 2013 12:23 pm Post subject: |
crm250 wrote: |
...dont suppose you know what size exhaust gasket these use would you ?
Cheers |
33 x 41 x 4  _________________ NS400R, YSR50, YSR125, Banshee, TDR250, KTM 500MX, Bimota V-Due, TDR80, Harris Rotax 250... |
crm250 Show Star !
Posted: Sat Jan 19, 2013 12:47 pm Post subject: |
yet again, top marks and thanks for that.
now if i could hassle / trouble you once again.
Could you possibly i beg you for a picture of the temp gauge and sender wiring ?
mine has the sender in the top of the rad but nothing connected. i can see 2 bullet connectors not doing anything.
Dont suppose you have a wiring diagram ?
i need a throttle cable / twistgrip.
the chimp that "upgraded" mine has stretched mine and trimmed the throttle grip pulley area to make it "fit" (why do people do this stuff ? they really should not be allowed tools)
so would you happen to either have part numbers, or know of a throttle plastic twist tube that is the same in the kawa range ? perhaps AR80 ?
the cable bit i need is the top part but would settle for the lot.
i removed the airbox and fixed the snorkel to the carb before attaching the snorkel back to the air box body so thats all done.
exhaust exit is bad news, so need to find some 20mm pipe to attach or get something welded back on.
genuine mirrors are required too.
new tyres
And for sure i need a head and base gasket at the very least. i want to refresh the top end. |
Terminaterre
Posted: Sat Jan 19, 2013 9:43 pm Post subject: |
I think I have a twistgrip and probably the other part you need. I have a mirror but not sure it's an genuine one.
I also have the wiring diagram (I'll scan it @ work on monday).
Pics will follow  _________________ NS400R, YSR50, YSR125, Banshee, TDR250, KTM 500MX, Bimota V-Due, TDR80, Harris Rotax 250... |
