S8xor
Posted: Mon Feb 04, 2013 12:37 pm Post subject: RG250 Engine in a 73 CB200 project |
Hi everyone being new to the site I though it was only right that I introduce myself. I thought I would upload some pics of my current project and give you some info.
The frame is a 73 Honda CB200, i got the whole bike for £50 but with so many bits missing or beyond repair I decided to build a "special". I have always wanted a bigger 2 stroke after owning 3 Aprilia RS125s when I was a teenager, so after searching for a few months I found a MK1 RG250 engine for £60 with a recent top end rebuild. So with the basic layout sorted I started shopping around for so many other bits that I think will either work or look great.
KLE500 wheels respoked to 17"
KLE500 rear brakes
CB400 94 rear shocks
CB200 swingarm extended 3" (still needs a loop and strengthing)
Aprilia RS125 front brakes inc master cylinder and lever
Derbi GPR 125 USD forks yokes and clipons (these may change to RS125 ones if I can find some cheap enough)
General brackets and metal work I have done with my limited space and machinery but it does me.
I am still on the lookout for loads of bits in the usual places. If you can help with any of the bits thanks in advance. I hope to upload more pics as the build progresses and give any updates
Heres that short list of the bits I need:
Carb inlet rubbers
Airbox
Loom
Exhausts
Regulator/rectifier
Cdi unit
Coil
Flywheel
Engine mounts
Cheers Dan
welshlee
Posted: Mon Feb 04, 2013 6:55 pm Post subject: |
hi,nice looking bike you have there, is it a cafe racer. _________________ 87 rg 250 gamma
1972 vw baywindow
5eb r6 fiat rossi rep |
S8xor
Posted: Mon Feb 04, 2013 10:19 pm Post subject: |
I am going for the cafe racer look but things change on a weekly basis at the mo. it is depending on what parts come up cheap that I think will work. There has been a few changes to date because I have put things together and it looked crap. |
S8xor
Posted: Fri Feb 08, 2013 5:55 am Post subject: |
I thought I should post a few more detail pics of the bits that have been finished in the last week,
Rear caliper carrier its a kle500 unit cut and shaped to size
The front caliper is an Aprilia RS125 unit, the bracket is a temp as I will me making a ali unit from 20mm plate tomorrow
Oh yer I thought I should add a pic of how I got the bike
