topfridgeman
Posted: Wed Mar 13, 2013 10:12 pm Post subject: SDR200 Info needed. |
Hello,
I need a bit of info on my sdr if someone has it. My bike is currently getting a pipe made for it. I could do with a good pipe design or the port timing for the sdr200, so that the tuner doesn't need to pull the top off my motor.
Anyone got any info?
The bike had a run on the dyno while I was there, and made 27hp at the rear wheel.
I've also got a scruffy but solid standard pipe for sale if anyone is interested.
Col. topfridgeman@hotmail.com |
Ibby4585
Posted: Thu Mar 14, 2013 5:13 pm Post subject: |
Hi.
Get some pics up of your SDR, it always nice to see different ones. I believe Martin77 on here made a very nice pipe for Arlurt's SDR, so it might be worth contacting him.
If you have no luck there I have two different race systems for my SDR's one is a Team Alpha racing pipe and the other is a Jackal. You could try copying.
To be honest both system come up quite a lot on Yahoo so it might be cheaper and a lot less hassle buying a ready made second hand pipe specifically designed for the 2tv.
Kris |
topfridgeman
Posted: Sun Mar 17, 2013 5:59 pm Post subject: |
Loving the dyno clips with Mr A smokin a cig.. Proper old school tuner
...and looks 60 when he's only 30... Lol ( only joking if you read this Mick !! ) _________________ We are where we are... |
Posted: Mon Mar 18, 2013 1:12 pm Post subject: |
This is the pipe Martin made for the SDR I have:
It runs with one of his alloy silencers.
There are more pictures on the thread about my bike in this section. _________________ Light is right. |
topfridgeman
Posted: Mon Mar 18, 2013 6:33 pm Post subject: Old school tuners |
Every tuner who's ever run one of my bikes has done it with a ciggy hangin out of his mouth.. With the exeption of Dean Ashton in Hull with our Mayhem racer.
Must be an occupational hazard!
Col. |
maccas
Posted: Mon Mar 18, 2013 8:18 pm Post subject: |
Col.
Does dean ashton still operate or has he closed down?
Sorry to thread hijack.
Cheers,
Dan |
topfridgeman
Posted: Tue Mar 19, 2013 7:29 pm Post subject: |
Not sure dude.
Col. |
fletch
Posted: Sat Apr 06, 2013 9:05 pm Post subject: |
| Hi Col, do you still need SDR port map? I gotta replace base gasket on my SDR so can get map for you when i pull it apart, be in couple of weeks |
Ianboom
Posted: Mon Apr 08, 2013 6:59 pm Post subject: |
If you can get a port map i'd appreciate it.
Just bought an SDR and want a pipe built up by Kenny at TSA
Ian |
fletch
Posted: Mon Apr 08, 2013 8:01 pm Post subject: |
| Ok no worries, i can do that, pulled it apart yesterday morning so will do it this week |
Ianboom
Posted: Mon Apr 08, 2013 8:20 pm Post subject: |
Cheers.
Can you strip the top end in the frame and what's spares availability like?
Ian. |
fletch
Posted: Mon Apr 08, 2013 8:48 pm Post subject: |
Topend came off with engine in frame, had to take rad off but thats no problem, gaskets on back order from Fowlers, be couple of weeks  |
Posted: Tue Apr 09, 2013 2:33 pm Post subject: |
Fletch, i was going to ask what the gasket situation was like on the SDR. I assume there are no problems then? Fowlers can get them. I thought the base gasket might be the same as a dt/wr 200.
Also Kenny at TSA has put out a request on another forum for the port map for the SDR. Be nice to see what TSA come up with and what sort of price etc. Don't forget the pictures!!!! |
Ianboom
Posted: Tue Apr 09, 2013 2:41 pm Post subject: |
When did Kenny put the request out?
Did some work with him on my hybrid lc, it had small can allspeeds on and made approx 53 bhp, with tsa pipes on the same jetting it made 62!
Would be interesting if he could get 30 bhpnon a stock sdr |
