		| S8xor
				|  Posted: Mon Feb 04, 2013 12:37 pm    Post subject: RG250 Engine in a 73 CB200 project |   |
				| Hi everyone being new to the site I though it was only right that I introduce myself. I thought I would upload some pics of my current project and give you some info.
 The frame is a 73 Honda CB200, i got the whole bike for £50 but with so many bits missing or beyond repair I decided to build a "special". I have always wanted a bigger 2 stroke after owning 3 Aprilia RS125s when I was a teenager, so after searching for a few months I found a MK1 RG250 engine for £60 with a recent top end rebuild. So with the basic layout sorted I started shopping around for so many other bits that I think will either work or look great.
 KLE500 wheels respoked to 17"
 KLE500 rear brakes
 CB400 94 rear shocks
 CB200 swingarm extended 3" (still needs a loop and strengthing)
 Aprilia RS125 front brakes inc master cylinder and lever
 Derbi GPR 125 USD forks yokes and clipons (these may change to RS125 ones if I can find some cheap enough)
 General brackets and metal work I have done with my limited space and machinery but it does me.
 I am still on the lookout for loads of bits in the usual places. If you can help with any of the bits thanks in advance. I hope to upload more pics as the build progresses and give any updates
 Heres that short list of the bits I need:
 Carb inlet rubbers
 Airbox
 Loom
 Exhausts
 Regulator/rectifier
 Cdi unit
 Coil
 Flywheel
 Engine mounts
 Cheers Dan
		| welshlee
				|  Posted: Mon Feb 04, 2013 6:55 pm    Post subject: |   |
				| hi,nice looking bike you have there, is it a cafe racer. _________________
 87 rg 250 gamma
 1972 vw baywindow
 5eb r6 fiat rossi rep
		| S8xor
				|  Posted: Mon Feb 04, 2013 10:19 pm    Post subject: |   |
				| I am going for the cafe racer look but things change on a weekly basis at the mo. it is depending on what parts come up cheap that I think will work. There has been a few changes to date because I have put things together and it looked crap. |  |
		| S8xor
				|  Posted: Fri Feb 08, 2013 5:55 am    Post subject: |   |
				| I thought I should post a few more detail pics of the bits that have been finished in the last week,
 Rear caliper carrier its a kle500 unit cut and shaped to size
 The front caliper is an Aprilia RS125 unit, the bracket is a temp as I will me making a ali unit from 20mm plate tomorrow
 Oh yer I thought I should add a pic of how I got the bike
