XR11/73
gagster55
PostPosted: Sun Dec 13, 2015 4:15 pm    Post subject: XR11/73 Reply with quote
squeezing a quart into a pint pot.........
or a GT750 motor into a GSX-R400 GK73A frame.
They said it couldn't be done........... Wink
PostPosted: Sun Dec 13, 2015 5:29 pm    Post subject: Reply with quote
Monster !!
I've seen a fantastic KH750 engine in a ZXR400 frame so should be ace, of course you need radiator too so tight squeeze indeed Smile
gagster55
PostPosted: Sun Dec 13, 2015 6:26 pm    Post subject: Reply with quote
a 750 Kawasaki triple is a lot shorter than a GT750 motor - honest !
charlieuk
PostPosted: Tue Dec 15, 2015 8:25 pm    Post subject: Reply with quote
Top-shaggy wrote:
Monster !!
this one? Have to admit I love it, so will be interested to see how this one turns out
http://www.zweitakte.de/projekte/ralf_zxr/zxr_h2.htm
gagster55
PostPosted: Wed Dec 16, 2015 12:47 pm    Post subject: Reply with quote
not seen that one before - thanks for the link Very Happy
I was toying with the idea of putting my spare GT750 motor into a H2 Kawasaki frame and making a proper triple (ooerrr) but having viewed a suitable donor frame on Monday, it's never going to happen.
So I'm on the lookout for another recipient............ Wink
gagster55
PostPosted: Wed Dec 16, 2015 12:53 pm    Post subject: Reply with quote
the top radiator.............
another fits across the frame, under the headstock.
nick69
PostPosted: Fri Dec 18, 2015 2:46 am    Post subject: Reply with quote
Excellent mate,looks like a neat solution
eyrey1
PostPosted: Fri Dec 18, 2015 3:24 am    Post subject: Reply with quote
my yz125 had a rad there when i was a lad i think it was 82 or 81 model if i remember right
gagster55
PostPosted: Sun Feb 14, 2016 5:08 pm    Post subject: Reply with quote
making the front engine mounting............
firstly, the cylinder head plate. I Araldited an oversized piece of aluminium sheet to a spare cylinder head so it wouldn't move around whilst marking it out and drilling it........
the head plate mounting bolts are 8mm, whereas the holes for the cylinder head mounting sleeve bolts are 13mm. To get the holes as accurate as possible, I cut an old sleeve bolt down........
and used it to centre the 8.5mm drill bit thus...........
so that after a visit to the pillar drill...........
and a little bit of shaping (to clear the thermostat housing).....
I ended up with this...........
some welding next..............
