rg250 Broken Ignition switch wires
how69
PostPosted: Wed Apr 10, 2019 8:03 pm    Post subject: rg250 Broken Ignition switch wires Reply with quote
Hi folks
need a hand does any one know witch 2 terminals these wires solder onto
i cant tell. dont know how to check it and dont want to re solder in the wrong place
it is the blue and white
and black and white wires
you can see the 2 solder spots on the back of ignition switch
the double spots are one connection
and to the left of it a dirty looking clump is the other connection
We will get there in the end
PostPosted: Thu Apr 11, 2019 9:28 am    Post subject: Reply with quote
No, but you can probably work it out.
Do you have a multimeter, or even a basic continuity tester ? Try it across pairs of terminals in turn, and work out which ones are connected, for each different position of the key. Presumably the switch has off, on, lock and parking-light settings as most do ?
Once you've worked out which terminals do what, you should know where to reattach the wires, based on what's currently not working.
