		| Author | Message |
		| Dixiesatellite
				|  Posted: Mon Jun 18, 2018 1:15 pm    Post subject: RG250 Gamma Engine Dimensions |   |
				| Hi,
 Here in Japan there are always loads of Gammas being sold or parted out, so I wanted to transplant a Gamma engine into a different frame. In order to decide if a Gamma engine will fit, can anyone tell me the following dimensions?
 1/   Width of the crankcase mounting points (to see how it matches up to the frame for adapters).
 2/    Width of installed exhaust pipes where they exit the heads (to see if there is enough clearance on the other frame.
 Thanks very much for your help.
 Cheers,
 Ian
		| Back to top |  |
		| Dixiesatellite
				|  Posted: Sun Jun 24, 2018 1:10 am    Post subject: RG250 Gamma Engine Dimensions |   |
				| Would anyone be able to tell me the dimensions of frame clearance when pipes are installed? I don't have a n RG250 here I can check at the moment. Just looking for how wide the L & R pipes are in this location where they exit the heads to see if this will work in the other frame. Thanks very much for your help.
 Ian
		| Back to top |  |
		| how69
				|  Posted: Sun Jun 24, 2018 10:24 am    Post subject: |   |
				| Hi  sorry for being a bit slow giving you info the length is 14.5 inches
 width is 14.5 inches
 the height is around about 10 inches as I dont have the barrels on so am gauging the height the studs are still in so a bit a bove that would be around 10 inch.
 hope this is good enough for you.
 We will get there in the end
		| Back to top |  |
		| how69
				|  Posted: Sun Jun 24, 2018 7:07 pm    Post subject: |   |
				| Sorry about giving you useless Info don’t know what I was reading
 But not what you wanted.
 The frame gap is 210mm wide
 I have not got the pipes on so cannot give dim of
 Those.
   click on picture for larger image
		| Back to top |  |
		| Dixiesatellite
				|  Posted: Sun Jun 24, 2018 10:21 pm    Post subject: |   |
	  | how69 wrote: |
 Those.
 Hi, that's great - thank you very much indeed for taking these measurements - it is a great help
 Cheers,
 Ian
		| Back to top |  |
