chris wilson
Joined: 14 Dec 2009 Posts: 7 Location: United Kingdom
Posted: Fri Jul 02, 2010 7:08 pm Post subject: ypvs help needed |
i im looking for any advice on a problem im having with my ypvs.
i can only get it to run on 1 cylinder at a time ,if i take any ht lead of and put a plug in that cap the other cylinder will fire ok first or 2nd kick. same when i swap them over but will not run together ,ive put 2 new plugs in in case they were bad but no joy.
any ideas would be much appreciated  _________________ chubba81 |
greengoatchoker
Posted: Sat Jul 03, 2010 12:44 am Post subject: |
well assuming when you swap the ht lead the problem follows . probably a damaged ht lead or cap not connected to cable properly . that would be where i would start _________________ a pig in the dark is still a pig |
chris wilson
Posted: Sat Jul 03, 2010 7:02 am Post subject: |
both leeds work independently the left 1 runs with right leed out and a plug on the frame and the right one with left out both give a good spark from the plug thats out and other cylinder runs . _________________ chubba81 |
